How Do You Express Vector C in Terms of A, B, and Theta?
  • Thread starter Thread starter swooshfactory
    Length Vector
The discussion focuses on expressing vector C in terms of vectors A, B, and the angle theta. The user initially attempts to use trigonometric identities, specifically sin[(180-theta)/2], to relate the components of vector C to A and B. A suggestion is made to simplify the problem by aligning vector C along the x-axis, allowing for the direct calculation of the x and y components of A and B. This approach facilitates the elimination of the angle phi, enabling a clearer expression of vector C solely in terms of theta.
  • Understanding of vector addition and components
  • Familiarity with trigonometric functions and identities
  • Knowledge of angles and their relationships in geometry
  • Basic skills in algebraic manipulation of equations
  • Study vector component analysis in physics
  • Learn about trigonometric identities and their applications in vector problems
  • Explore the concept of angle bisectors in geometry
  • Research methods for eliminating variables in equations
Students studying physics or mathematics, particularly those focusing on vector analysis and trigonometry, will benefit from this discussion.
swooshfactory
The question asks to express vector C in terms of A, B, and theta.
I would guess the relevant equations to be trig equations.
I found sin[(180-theta)/2] = k/B (k is a variable I set to equal the right bisected part of C when the angle c was divided in two). Also, sin[(180-theta)/2]= j/A.
c= 180 - theta. After that however, I don't know how to incorporate theta without using phi. Can you assume that a line stretching from the angle to to make a right angle with vector C bisects the angle into two equal angles? That was how I attempted to solve the problem, but I'm not sure if that works. Any help would be greatly appreciated. Thanks in advance.
I think you are letting your trigonometry get ahead of your vector addition.
I would suggest developing equations for the x and y components of A and B that would serve to yield C.
For simplicity I might suggest letting C lie along the x-axis. Then you know the y-components of the A and B vectors must sum to 0 and the x will sum to C.
From those equations then look to eliminate any functions of the angle ϕ and leave things in terms of θ.
  • · Replies 18 ·
  • · Replies 32 ·
