Amusment park yesterday for physics class
  • Thread starter Thread starter Format
    Class Physics
The discussion centers on calculating the acceleration of the "hellevator" amusement park ride during its initial ascent. To determine this acceleration, one can use the formula a = 10/T², where T is the time taken to ascend the first 5 meters. After reaching this height, the ride's motion is influenced by gravity, requiring the use of equations for velocity and height to analyze the ride's dynamics. Key variables include initial velocity (0 m/s), final velocity (calculated from free fall), and the effects of gravity (9.8 m/s²) on the ride's performance.
  • Basic understanding of kinematics and motion equations
  • Familiarity with the concepts of acceleration and gravity
  • Knowledge of the equations for velocity and height in physics
  • Ability to perform algebraic manipulations to solve for unknowns
  • Study the kinematic equations for uniformly accelerated motion
  • Learn about the effects of air resistance on moving objects
  • Explore the principles of energy conservation in amusement park rides
  • Investigate real-world applications of physics in engineering amusement rides
Students studying physics, physics educators, amusement park engineers, and anyone interested in the mechanics of amusement park rides.
Format
When to an amusment park yesterday for physics class. Went on a ride called the "hellevator" where you sit down and it shoots up a certain distance then let's you free fall. My question is if the acceleration upwards occurs in the first 5 meters how do you figure out that acceleration?
You are going to need more information to find the acceleration.
Given an acceleration of a m/s2, the speed after t seconds is v= at and the height is h= (1/2)at2.
If you know the time, T, taken to get to that first 5 meters, you could solve
5= (1/2)a(T2): a= 10/T2.
After that first time, T, you continue upwards under the influence of grativity:
you speed at time t will be v= -g(t-T)+ aT and height will be h= 5+aTt- (1/2)g(t-T)2.
At the maximum height, v= -g(t-T)+ aT= 0 so you can solve for t (in terms of T). If you know that maximum height (usually easier to measure than time), you could solve the second equation for a.
To calculate the acceleration in the first 5 meters of the "hellevator" ride, you would need to use the equation a = (vf - vi)/t, where vf is the final velocity, vi is the initial velocity, and t is the time interval. In this case, the initial velocity is 0 because the ride starts from rest, and the final velocity can be calculated using the free fall equation vf = vi + at, where a is the acceleration due to gravity (9.8 m/s^2) and t is the time it takes for the ride to reach the top. Once you have the final velocity, you can plug it into the first equation to solve for the acceleration. Keep in mind that the acceleration will be negative since the ride is moving upwards, while gravity is pulling downwards. It is also important to note that this calculation assumes that the ride is moving at a constant acceleration, which may not be the case in reality. Other factors such as air resistance and mechanical limitations of the ride may affect the acceleration. Overall, understanding the physics behind amusement park rides can add a fun and educational element to the experience.
  • · Replies 18 ·
