Minus signs on Voltage and potential energy
The discussion centers on the concepts of electric potential and potential energy in the context of electric charges. It is established that at a midpoint between a positive and negative charge of equal magnitude, the electric potential is zero while the electric field is not. Additionally, when moving an electron from a positive to a negative terminal, the change in potential energy is positive because work is done against the electric field. The work-energy principle indicates that doing work on a system increases its energy, which applies to potential energy in this scenario.
  • Understanding of electric potential and electric fields
  • Knowledge of potential energy concepts in electrostatics
  • Familiarity with the work-energy principle
  • Basic principles of charge interactions
  • Study the relationship between electric potential and electric fields
  • Learn about the work-energy principle in electrostatics
  • Explore the concept of potential energy changes in electric fields
  • Investigate the behavior of different charge types in electric fields
Students and professionals in physics, electrical engineering, and anyone interested in understanding the principles of electrostatics and energy interactions in electric fields.
blumfeld0
Just two quick questions
1. if you have a positive charge and a negative charge of equal magnitude and you pick a point directly half way between then
is the electric potential zero but the electric is not?? is that true? why?
2. if you take an electron and move it from positive to negative terminal is the change in potential energy negative or positive?
what is the rule for determining if a change in potential energy is positive or negative?
thank yo u
Don't understand your question. The electric what is not?
You mean change in PE of the electron? If so, then ask yourself if moving the electron from positive to negative entails doing work on the electron (ie. going against the field). If it is doing positive work, then the work done on the electron added to its potential energy (by the work-energy theorem).
EDIT: Ok, it's not called the work-energy theorem here (which seems to apply only to KE), I forgot what the law is called, but it's the one which says that doing work on some system means increasing the system's energy (whether kinetic or potential).
Hi Sorry for that.
for number one I meant to say electric field
for number 2 yes I mean the change in PE of the electron.
So because it is a negative charge (electron) and we are going against the field it will be POSITIVE work
but if it were a positive charge and we are going against the field it will be negative work
right?
  • · Replies 22 ·
  • · Replies 23 ·
