Calculating Minimum Trailing Distance in a Reaction Time Scenario
  • Thread starter Thread starter Argento7
    Minimum
The problem involves calculating the minimum trailing distance required to avoid a collision while driving, considering a reaction time delay before applying brakes. The context is set on a highway scenario with cars traveling at a constant speed.
  • The original poster attempts to understand how to incorporate a 1-second reaction time delay into their calculations. Some participants suggest that the distance covered during this delay is crucial for determining safe trailing distance.
Participants are exploring the implications of the reaction time on the distance needed to maintain safety. Some guidance has been offered regarding the relationship between speed, time, and distance, but there is no explicit consensus on the final calculation.
The discussion includes references to specific equations and a graph that could aid in visualizing the problem, but the exact values for acceleration are not provided, and assumptions about maximum braking are being questioned.
Argento7
Hello,
You are driving along the New York State Thruway in a line of cars all traveling at a constant speed of 108.1 km/hr (Which I converted to 30.02 m/s). The car in front of you applies its brakes for maximum acceleration. You then apply your brakes to achieve the same maximum acceleration after only a 1 s delay due to reaction time. What distance behind the car in front of you must you be to avoid a collision?
How can I factor in the 1s delay on the time?
All the equations for the problem are located here:
http://www.glenbrook.k12.il.us/gbssci/phys/Class/1DKin/U1L6a1.gif
I set the origin and my initial position to 0 for the car in front of you. I also had tried several times to figure out the acceleration.
Argento7 said:
Hello,
Welcome to PF.
Hint: You don't need to know actual acceleration. Just that it is the same and yours is 1 s later.
If you plotted a graph of velocity for each car they will look the same ... except for the 1 sec delay. So long as you start deceleration before you reach the point on the road that the car ahead starts then you should maintain the same distance to stopping.
For a 1 second margin then how does that translate into distance?
Hi, you were traveling at 30.02m/s, so in 1 second you will cover 30.02m, and you need 1 second to react. So at least you have to be a 30.02 meters distance from the car that is ahead of you.
There you go. You're ready to drive safely.
Thank you both so much :approve:
  • · Replies 33 ·
  • · Replies 29 ·
