Vectors find following in terms of x
  • Thread starter Thread starter BeckyStar678
    Terms Vectors
The problem involves expressing certain vectors in terms of a variable x, with specific lengths and angles given for the vectors m, n, o, and p. The original poster describes two configurations resembling roof shapes, with angles and directions that create confusion regarding the relationships between the vectors.
  • The original poster attempts to visualize the problem by extending vector x to form right triangles, questioning whether this approach is valid. Other participants express difficulty in understanding the problem without a clear diagram and question the clarity of the original poster's explanation. There are also inquiries about how to approach additional questions related to the vectors provided.
The discussion is ongoing, with participants seeking clarification and additional visual aids. Some guidance has been offered regarding the need for clearer explanations and diagrams, but no consensus or resolution has been reached yet.
The original poster mentions confusion regarding the setup of the problem and the relationships between the vectors, indicating potential gaps in information or understanding. There are also references to specific vector equations that may require further exploration.
BeckyStar678
express the following in terms of x, given that m,n,o and p are each 8 m long.
so the first diagram has x pointing upward and then m connected, pointing downward (forming roof shape) and the angle formed is 140 degrees (under the roof).
the next one is also a roof shape but x and n are pointing in diff dirrections instead of the same way. if x is extended, i can't really make a right triangle. so I am confused.
fr the first one, do i just extend x to make a right triangle on m and then get 40 degrees for one of the angles. so i would get 6 for the line that was extended. is this the answer?
I can't visualise this problem and can't understand what it is you are actually trying to express in terms of x...
Short of drawing a diagram, do you think you've explained the problem well enough for someone here, someone who's never seen the problem before, to answer it?
Sorry Becky I know i asked you to draw a diagram but I still can't quite get my head round this..
You might want to repost this problem if no one replies to this post.
  • · Replies 26 ·
