Is A Skew Symmetric?
The discussion revolves around proving that a real matrix A is skew symmetric, specifically under the condition that for every vector x in R^n, the scalar product equals 0. The focus is on mathematical reasoning and proofs related to linear algebra properties of matrices.
  • Some participants propose that if = 0 for all x in R^n, then A must be skew symmetric, leading to the conclusion A^t = -A.
  • One participant suggests writing out in terms of matrix components a_{ij} and manipulating the expression to derive conditions on the elements of A.
  • Another participant mentions an alternative approach that avoids using components, suggesting to analyze the expression to derive properties of A.
  • There is a reference to the adjoint definition, where = is used to relate properties of A and its transpose.
  • One participant humorously notes that a previous argument may have inadvertently proven the transpose of the original theorem instead of the intended result.
Participants generally agree on the approach to proving that A is skew symmetric, but there are multiple methods proposed, and the discussion remains exploratory without a definitive consensus on the preferred method.
Some steps in the mathematical reasoning are not fully resolved, and assumptions about the properties of the scalar product and matrix elements are implicit in the discussion.
TTob
Let A in n x n real matrix.
For every x in R^n we have <Ax,x>=0 where < , > is scalar product.
prove that A^t=-A (A is skew symmetric matrix)
Hi TTob! :smile:
Hint: just write out <Ax,x>=0 in terms of Aij etc …
then jiggle it around a bit! :smile:
What do you get?
Thank you.
note [tex]x=(x_1,...,x_n)[/tex] and [tex]A=(a_{ij})[/tex].
then [tex](Ax)_i=[/tex] [tex]\sum_{\substack{0\leq j\leq n}} a_{ij}x_j[/tex]
then
[tex]<Ax,x>=[/tex] [tex]\sum_{\substack{0\leq j\leq n \\ 0\leq i\leq n}} a_{ij}x_i x_j=0[/tex]
when you put [tex]x=e_i[/tex] you get [tex]a_{ii}=0[/tex] for all i.
when you put [tex]x=e_i+e_j[/tex] you get [tex]a_{ii}+a_{ij}+a_{ji}+a_{jj}=0[/tex] for all i,j .
so [tex]a_{ji}=-a_{ij}[/tex] for all i,j and then [tex]A^t=-A[/tex].
Hi TTob! :smile:
Yes … or if you want to avoid using components …
[tex]0\ =\ <A(x+y),x+y>\ -\ <Ax,x>\ -\ <Ay,y>\ \ =\ \ <Ax,y>\ +\ <Ay,x>\ \ =\ \ <(A + A^T)x,y>[/tex] :smile:
Or use the fact that <Ax, y>= <x, ATy>. (That is a more general definition of "adjoint")
From that, <Ax, x>= <x, ATx>. If A is skew-symmetric, <x, AT x>= -<Ax, x> so <Ax, x>= -<Ax, x> and <Ax, x>= 0.
HallsofIvy said:
… <Ax, x>= <x, ATx>. If A is skew-symmetric, <x, AT x>= -<Ax, x> so <Ax, x>= -<Ax, x> and <Ax, x>= 0.
Hi HallsofIvy! :smile:
erm …
I think you've proved the transpose of the original theorem! :wink:
