(Simple) Vector Problemdon't see what I'm doing wrong
  • Thread starter Thread starter shadowmystic9
    Vector
The discussion centers on a vector problem where vector B is added to vector C, defined as C = 3.7i + 4.9j, resulting in a vector aligned with the positive y-axis with the same magnitude as C. The magnitude of vector C is calculated to be 6.14. The user incorrectly applies the Pythagorean theorem to find the magnitude of vector B, leading to an erroneous result of 8.68. The correct approach involves recognizing that vector B must have components that, when added to vector C, yield a resultant vector with the same magnitude as C, specifically in the y-direction.
  • Understanding of vector addition and components
  • Familiarity with the Pythagorean theorem
  • Knowledge of vector magnitude calculation
  • Basic algebra skills
  • Review vector addition principles in physics
  • Study the concept of vector components and their representation
  • Learn about resultant vectors and their properties
  • Practice problems involving vector magnitudes and directions
Students studying physics or mathematics, particularly those focusing on vector analysis and problem-solving techniques in vector addition.
shadowmystic9
(Simple) Vector Problem..don't see what I'm doing wrong!
If the vector B is added to vector C = 3.7 i + 4.9 j , the result is a vector in the positive direction of the y axis, with a magnitude equal to that of C. What is the magnitude of B?
Here is what I did -
Magnitude is r = sq rt of Ax^2 + Ay^2 components
therefore, the magnitude of C is
3.7^2 + 4.9^2, take sq rt = 6.14 = magnitude of C
The question is for the magnitude of B. The resultant vector, according to the problem, has the same mag as C, so I would use the Pythagorean theorem =
A^2 + b^2 = C^2
6.14 ^2 + 6.14 ^2 = 75.3992, take sq rt = 8.68.
However this answer is not correct. I do not see where I went wrong, please help. Thank you!
Your question is difficult to follow. From the statement of the problem, start by writing
Bx i + By j + Cx i + Cy j = sqrt[ (Cx)^2 + (Cy)^2 ] j
What's the next step?
  • · Replies 17 ·
