Thermal Conductivity Definition
Thermal conductivity quantifies the rate of heat transfer through a material, defined as the heat in calories per second passing through a 1 cm thick body with a 1 sq. cm cross-section when there is a 1°C temperature difference. For recrystallized Alumina, the thermal conductivity index is 38.7 mcal/s/(cm°C/cm), indicating that 1 cubic centimeter absorbs 0.0387 cal/second with 1 sq. cm in contact with a heat source. The discussion also clarifies the conversion between units, confirming that 1 (cal/sec)/(cm²°C/cm) is equivalent to 419 W/m·K, and addresses the confusion regarding the relationship between 419 W/m·K and 4.19 W/cm·K.
  • Understanding of thermal conductivity concepts
  • Familiarity with heat transfer principles
  • Basic knowledge of unit conversions in thermodynamics
  • Proficiency in using scientific formulas for heat calculations
  • Research the formula for calculating heat transfer rate in ideal systems
  • Study the properties and applications of thermal conductivity in materials science
  • Explore unit conversion techniques in thermodynamics
  • Learn about the specific heat capacity and its relationship to thermal conductivity
Students and professionals in materials science, engineers working with thermal systems, and anyone interested in the principles of heat transfer and thermal properties of materials.
Kasper_NYC
Hi,
I have read that Thermal Conductivity means: “The thermal conductivity of a substance is the quantity of heat in cal/sec passing through a body 1 cm thick with a cross section of 1 sq. cm when the temperature difference between the hot and cold sides of the body is 1 deg. C.” http://www.lib.umich.edu/dentlib/Dental_tables/Thermcond.html
Does it means also how fast a substance can increase or decrease its temperature when is in contact with a heater or colder fount? For example, will it means that in the case of the Alumina (recrystallized), that its index is 38.7 (mcal/s) / (cm^ C/ cm), 1 cubic centimeter will absorbs 0.0387 cal /second, having 1 square cm of surface in contact with the heat fount?
I am interested into find the formula that let's to calculate how fast a given mass of substance warms up or colds down by second, in an ideal system (without losses of heat).
The other question is if “1 (cal/sec) / (cm2 C/cm) = 419 W/m K”; is 419 W/m K equivalent to 4.19 W/m K? (http://hyperphysics.phy-astr.gsu.edu/Hbase/tables/thrcn.html#c1)
Thanks a lot.
PS – I apologize for my English, I am learning it.
Science news on Phys.org
Excuse me please,
The other question should be: " If 1 (cal/sec) / (cm2 C/cm) = 419 W/m K”; is it 419 W/m K equivalent to 4.19 W/cm K?"
Thanks again.
  • · Replies 16 ·
15K
  • · Replies 19 ·
  • · Replies 27 ·
  • · Replies 16 ·
