Intereference of light (at least i think it is) and the human eyeball
  • Thread starter Thread starter kehler
    Human Light
The discussion centers on the relationship between the dimensions of the human eyeball and the spacing of light receptors on the retina. The diameter of the human pupil can reach up to 5mm, while the spacing of light receptors is at least 2 micrometers. Calculations using the formula d sin θ = n λ reveal that the distance between maxima for violet light (400nm) is 1.2 micrometers and for red light (700nm) is 2.1 micrometers. This indicates that the spacing of the receptors is not coincidental but rather a function of the eye's optical design.
  • Understanding of light diffraction and interference patterns
  • Familiarity with the formula d sin θ = n λ
  • Basic knowledge of human anatomy, specifically the structure of the eye
  • Concept of resolving power in optics
  • Research the resolving power of circular apertures in optics
  • Study the principles of light diffraction and interference
  • Explore the anatomy of the human eye and its optical properties
  • Investigate the effects of different wavelengths of light on visual perception
Students in optics, biology, and physics, as well as educators teaching about the human eye and light behavior, will benefit from this discussion.
kehler
A human eyeball has roughly a diameter of 15mm. The diameter of the pupil can be up to roughly 5mm. Do you think that the fact that the light receptors on the retina are spaced by at least 2 micrometers is just a coincidence? Justify your answer.
I don't know exactly what the question wants.
I considered the pupil to be a slit, used d sin theta = n lambda for lambda = 400nm (wavelength of violet), and then found that the distance between maxima for violet is 1.2 micrometers. For lambda = 700nm (red light), the distance between maxima is 2.1 micrometres.
I expected both values to be either greater than or less than 2 micrometers. (Then I could make up some crappy explanation about having the distances between maxima for all the colours to be greater/less than 2 micrometers :redface:)
But obviously that didn't work for me so I guess that's not the right way to do it. Any ideas how to do this?
Hi kehler,
I believe this problem is referring to the resolving power of a circular aperture. Your textbook probably has a section or part of a section talking about it.
  • · Replies 33 ·
  • · Replies 96 ·
13K
