Solving Exercise 8.9 from ECE 3025 Lecture Notes
The discussion revolves around solving Exercise 8.9 from the ECE 3025 lecture notes, which involves a circuit with switches and transmission lines. Participants are seeking clarification on how to approach the problem given the lack of relevant information in the provided lecture notes.
  • Homework-related
  • The original poster expresses confusion regarding the problem due to the absence of information about switches in the lecture notes.
  • One participant suggests considering the system immediately after the first switch is closed, mentioning the 20V source and output impedance, and proposes a voltage divider effect between the source and the transmission line.
  • The original poster indicates that their attempt at a solution does not yield sensible results, suggesting that the numbers are incorrect.
  • Another participant emphasizes that the forum does not provide direct answers to homework questions but encourages the original poster to share their work for further assistance.
Participants do not reach a consensus on the solution to the problem, and there is ongoing uncertainty regarding the correct approach and calculations.
There are limitations in the original poster's understanding due to missing information in the lecture notes, and the discussion reflects a lack of clarity on how to apply the concepts to the specific problem.
r3dxp
http://img168.imageshack.us/my.php?image=eightss5.png
I have the lecture notes that is 14pages long that covers this particular chapter and the lecture note provided by my professor does not mention anything with switchs in the lecture note whatsoever.. so I am confused on how to solve this problem. the link to the full lecture note/problems is..
http://www.prism.gatech.edu/~bpark6/ECE/ECE3025/Tline2008_08.pdf
The problem in the imageshack.us is exercise number 8.9. THanks a lot in advance.
I'm afraid I'm only going to be of a little bit of help here, but hopefully it gets you going more. Immediately after the first switch is closed, what do you have for a system? You have the 20V source with output impedance Zo, and it is starting to drive a pulse down the lefthand transmission line, right? Would you get some sort of a voltage divider effect between the output Zo of the source, and the input Zo of the TL? What could you say is the amplitude of the pulse as it starts propagating down the lefthand TL?
thanks berkeman. i tried that but my answer does not make sense. i believe the numbers are way off.
can anybody figure out the solution to this problem? Hope to hear from anybody soon. Thanks in advance.
Sorry, that's not how the PF works for homework and coursework questions. We do not give out answers or do your work for you. We can offer tutorial help as long as you show us your work.
Show us what you have done so far -- why does your initial answer not make sense?
  • Sticky
  • · Replies 0 ·
  • · Replies 48 ·
14K
