Solving for Time: Dropped Pop Can Reaches the Ground
  • Thread starter Thread starter powerxranger1
    Ground Time
The problem involves a hot air balloon rising at a constant velocity of 4 m/s, from which a can of pop is dropped at a height of 4 m. The objective is to determine the time it takes for the can to reach the ground, considering its initial upward velocity and the effects of gravity.
  • Participants discuss the initial conditions of the can's motion, including its initial upward velocity and the displacement. Questions arise regarding the final velocity and the necessary kinematic equations to use. There is uncertainty about how to incorporate the acceleration due to gravity into the calculations.
Some participants are exploring the implications of free fall on the can's motion and are attempting to identify the necessary information to solve for time. Guidance has been offered regarding the importance of considering the signs of the variables involved in the equations.
Participants note the limited information provided in the problem statement, which includes only two numerical values. There is an ongoing discussion about the assumptions related to the can's motion and the effects of gravity.
powerxranger1
A hot air balloon is rising upward with a constant velocity of 4m/s. As the balloon reaches a height of 4m above the ground the balloonist accidently drops a can of pop over the edge of the basket. How long does it take the pop can to reach the ground?
V2 = 4m/s [up]
v1 = 0
d = 4m
d=1/2 (v2 + v1) t
I got the anser 2 seconds! Please tell me if i did it correctly
Hi powerxranger1,
V2 = 4m/s [up]
v1 = 0
d = 4m
d=1/2 (v2 + v1) t
No, I don't believe that's right. The initial velocity of the can is 4m/s upwards, like you have, but the final velocity is not given. (The final velocity in this case would be the velocity just before the can touches the ground, so it would not be zero.)
So you know the initial velocity and the displacement (but check the signs!); what else do you know about the can's motion? That will help you choose the best kinematic equation to find the time.
Hm, I'm not really sure that there is any other information given about the can, since there's only two numbers given. I don't understand how to find another piece of information.
The can is in free fall; what does that tell you? That will give you the third quantity, and so you can find the time.
Oh. Does that mean it's just 9.8 m/s?
Yes, that's the right magnitude for the acceleration. (And the units are m/s^2.) Just remember to use the correct signs for the initial velocity, displacement and acceleration when you use them in your equation.
9K
  • · Replies 21 ·
