Thread Closed
AP Physics 2-D Motion cramming and could use much much help please!
Share Thread Thread Tools
Sep10-08, 05:47 PM   #1
A rocket is intially at rest on the ground when its engines are fired the rocket flies off in a straight line at an angle of 53.1 degrees abovie the horizontal with a constant acceleration of magnitute g, the engines stop at time T after launch after which the rocket is a projectile Ignore air resistance and assume g is independant of altitude
C) Find the max altitude reached by the rocket andswer in terms of g and T
D) Find the horizontal distance from the launch point to where the rocket hits the ground answer in terms of g and T
(already got A and B CD are the last two)
2. Relevant equations
Im thinking that you use
y= 1/2gt^2 + Voyt+ Yo
3. The attempt at a solution
y=1/2gt^2 + Voyt+ Yo
y= 1/2 .8gT^2+0T+0
y=1/2 .8gT^2
now i got the .8 from using Voy=vsin53.1 is that correct?
and then after all that I just added that equation to the distance from when the rockets turned off the engines to when the verticle velocity would = 0... can someone please do this problem and explain in detail the best you can for each step and why you did it, i dont even know where to start with D
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
Sep11-08, 05:55 AM   #2
Recognitions:
Homework Helper Homework Help
Quote by Drewser View Post
y= 1/2 .8gT^2+0T+0
y=1/2 .8gT^2
The initial velocity of the rocket is[tex]v_0[/tex] [tex]v_{0y}[/tex] is its y-component. The initial velocity of an object that is accelerated from rest is always zero and so [tex]v_{0y}=0[/tex].
The equation for the height of the rocket at a time [tex]t[/tex] should be
[tex]y=\frac{1}{2}a_yt^2+ v_{0y}t+y_0[/tex]
not [tex]y=\frac{1}{2}gt^2+ v_0yt+y_0[/tex]
where [tex]a_y=gsin(53.1^{\circ})[/tex].
In addition, there is no reason to assume that the rocket reaches its maximum height at time [tex]t=T[/tex]; just because the rocket stops accelerating at [tex]t=T[/tex], does not mean that it suddenly stops moving. Instead, it will begin decelerating due to gravity starting with an initial velocity [tex]v_T=v(T)[/tex] until it reaches a maximum height, at which [tex]v_y=0[/tex], at some time later than [tex]T[/tex] and then continue falling until it hits the ground.
To calculate this height, you will first need to determine [tex]v_T=v(T)[/tex] from [tex]v_y(t)=a_yt+v_{0y}[/tex] and then find the time at which the rocket reaches its maximum height i.e. when [tex]v=0[/tex] (of course [tex]v=0[/tex] both at [tex]t=0[/tex] and at [tex]t=t_{max}[/tex] but you are obviously looking for the [tex]t=t_{max}>T[/tex] solution) and then finally you can use the equation [tex]y=\frac{1}{2}a_yt^2+ v_{0y}t+y_0[/tex] to find [tex]y_{max}=y(t_{max})[/tex]. Be careful to use [tex]a_y=gsin(53.1^{\circ})[/tex] only for the part where the rocket is accelerating upwards (i.e. when [tex]T>t>0[/tex]) and [tex]a_y=-g[/tex] when the rocket stops firing and starts falling due to gravity. Also I strongly recommend you post both the questions for (a) and (b) as well as your solutions, so that we can check them. After you properly work out (a), (b), and (c) I will help you with part (d).
Thread Closed
Tags
2d projecticle
Thread Tools
Similar Threads for: AP Physics 2-D Motion cramming and could use much much help please!
Thread Forum Replies
Has anyone ever received good marks on their finals after cramming? Academic Guidance 9
Photon cramming General Physics 4
Physics Motion Help Introductory Physics Homework 6
Possible to complete senior high school algebra&geometry course w/ 3 weeks cramming? Academic Guidance 5
physics help on motion in 1-d please help General Physics 1
