Maximizing Distance from Wall with Torque Beam Problem
  • Thread starter Thread starter gnsdraw
    Beam Torque
The discussion revolves around solving the torque beam problem involving a beam supported by a rope and friction against a wall. The beam has a weight W, a coefficient of friction of 1/2, and is positioned at an angle of 37 degrees. Participants emphasize the importance of analyzing the forces acting on the beam, including the normal force (N), friction force (F), and tension force (T), to determine the maximum distance (x) a man can stand from the wall without causing the beam to slip.
  • Understanding of torque and its calculations
  • Knowledge of static friction and its coefficients
  • Familiarity with force diagrams and components
  • Basic principles of equilibrium in physics
  • Study the principles of torque in static equilibrium
  • Learn about the calculations for normal and friction forces
  • Explore force component analysis in physics
  • Investigate real-world applications of beam stability and friction
Physics students, engineers, and anyone interested in mechanics, particularly those studying static equilibrium and torque applications in structural analysis.
gnsdraw
Torque beam problem?
| \ rope
|wall \
|...beam...37*
x |w
a beam is being held up by the rope due to the friction of the wall. the beam has a weight W, and a man is standing x distance away from the wall. the coefficient of friction with the wall is 1/2, the angle is 37*. what is the maximum distance towards the wall that the man can stand without falling.
i don't know how to start, the only thing i can think of is to use the torque at the angle =[
pic got messed up, rope on angle, wall on left
gnsdraw said:
| \ rope
|wall \
|...beam...37*
x |w
Hi gnsdraw! :smile:
(hmm … use CODE tags … :wink:)
Code:
|  \ rope
|wall \
|...beam...37*
x |w
Hint: call the normal force N the friction force F and the tension force T.
When the beam is about to slip, F/N will be exactly 1/2, won't it? :wink:
So take horizontal and vertical components of all the forces acting on the beam. :smile:
so along with fric force and tension, there are also going to be two weights? could anyone show me how to set the torques up
  • · Replies 42 ·
  • · Replies 28 ·
