Why do pendulums swing more slowly at the equator?
  • Context: Undergrad
  • Thread starter Thread starter Blue_Jaunte
    Equator Swing
Pendulums swing more slowly at the equator due to the Earth's oblate shape and rotation. The gravitational acceleration at the equator is approximately 9.780 m/s², which is about 0.052 m/s² less than at the poles, resulting in a longer period for pendulum swings. The centrifugal force caused by the Earth's rotation contributes 0.034 m/s² to this effect, accounting for roughly 65% of the difference in gravitational acceleration. Additionally, altitude and local density variations play minor roles in gravitational differences.
  • Understanding of pendulum physics, specifically the formula for period: T = 2π√(l/g).
  • Knowledge of gravitational acceleration variations, particularly at different latitudes.
  • Familiarity with the concept of centrifugal force in rotating reference frames.
  • Basic comprehension of Earth's shape and its effects on gravity, including the J2 non-spherical harmonic term.
  • Research the effects of Earth's rotation on gravitational acceleration in detail.
  • Explore the J2 non-spherical harmonic term and its implications for satellite orbits.
  • Study the relationship between altitude and gravitational force, particularly at high elevations like Mount Everest.
  • Investigate the concept of centrifugal force and its relevance in non-inertial reference frames.
Physicists, educators, and students interested in gravitational physics, pendulum mechanics, and the effects of Earth's shape and rotation on physical phenomena.
Blue_Jaunte
I was asked this recently and the only explanation I could come up with was that the Earth is oblate and the difference in R would account for the difference in the period. Is this wrong? Is this even a real phenomenon (the longer period at the equator than at other latitudes)?
The period of a pendulum is [tex]2\pi\sqrt{l/g}[/tex] so if g is less the period (time for a swing) becomes longer. g varies by a few percent around the world dependign on the density of local rocks.
Tt also depends on latititude because, as you said, the Earth bulges at the equator and so you are futrther from the centre of the Earth and the force of gravity is slightly lower.
A pendulum swings slower at the equator because the Earth is rotating. The rotation acts to make the pendulum swing slower directly and indirectly. The direct effect is easiest to envision from the perspective of the rotating Earth-fixed frame. In this frame, a centrifugal force of [itex]r\omega^2[/itex] arises directly from the Earth's rotation. At the equator, this direct effect alone amounts to 0.034 m/s2. There is of course no centrifugal force at the poles.
For those who insist there is of course no such thing as centrifugal force anywhere, you will be forced to look at things from the perspective of an inertial frame. I leave this as an exercise to you curmudgeons. Keep in mind that the answer you get will be the same.
I also cited an indirect effect that results from rotation. The Earth's rotation makes the Earth bulge at the equator. As mgb_phs noted, this makes things at the equator further from the center of the Earth. Together, the direct and indirect effect act to make Earth's gravitational acceleration 9.780 m/s2 at the equator. This is about 0.052 m/s2 less than it is at the poles, or a 0.53% reduction in the gravitational acceleration. The direct effect accounts for about 65% of the difference.
The next leading factor in variations in gravitational acceleration after Earth rotation and the J2 non-spherical harmonic term is altitude above the spheroid. Things weigh 0.28% less at the top of Everest than they do at sea level at the same latitude. Local variation in density is a distant fourth.
  • · Replies 25 ·
  • · Replies 41 ·
