How Do You Calculate Time and Velocity of a Rocket-Powered Ice Sled?
  • Thread starter Thread starter avabby
    Linear
The discussion focuses on calculating the time and velocity of a rocket-powered ice sled that accelerates at +11.0 m/s², travels a total distance of 5,300 m, and has a total time of 81.0 s. The first step involves using kinematic equations to separate the sled's motion into two phases: acceleration and constant velocity. The correct approach requires applying the equation d = Vi*t + 0.5at² for the acceleration phase and a separate equation for the constant velocity phase, ultimately leading to the use of the quadratic formula to solve for the unknowns t1, t2, and v.
  • Kinematic equations for motion under constant acceleration
  • Quadratic formula for solving equations
  • Understanding of velocity and acceleration concepts
  • Basic algebra skills for manipulating equations
  • Study the complete set of kinematic equations for motion with constant acceleration
  • Learn how to apply the quadratic formula in physics problems
  • Explore examples of motion analysis involving multiple phases of acceleration
  • Practice problems involving distance, time, and velocity calculations in physics
Students studying physics, particularly those focusing on kinematics, as well as educators looking for examples of motion analysis involving acceleration and constant velocity scenarios.
avabby
An ice sled powered by a rocket engine starts from rest on a large frozen lake and accelerates at +11.0 m/s2. At t1 the rocket engine is shut down and the sled moves with constant velocity v until t2. The total distance traveled by the sled is 5.30x10^3 m and the total time is 81.0 s.
Find t1, t2, and v.
so,
a= +11.0 m/s^2
deltat= 81.0 s
deltax or d= 5300 m
t1= ?
t2= ?
v= ?
well, i tried to use:
1. d= Vi*t + .5at^2
2. d= Vi + at^2
^ I'm not sure if those are right to use.
Okay, well what I did first was this:
I used the first equation listed and put in everything I knew, which ended up with this:
d= 5.5t^2
Then, I used the second equation to also solve for d.
d= 11t
I know the entire distance is 5300m, so I then did:
5300= 5.5t^2 + 11t
however, I'm not exactly sure as to where i can use the deltat of 81.0s. I know that I'm going to have to use the quadratic formula from here, but I don't know what to do. I was thinking of doing something like this:
5300= 5.5t^2 + 11t (81-t)
But, I'm not sure that is accurate.
I'm stuck right now as of what to do. Help would be muchh appreciated. Thanks!
Hi avabby,
Find t1, t2, and v.
so,
a= +11.0 m/s^2
deltat= 81.0 s
deltax or d= 5300 m
t1= ?
t2= ?
v= ?
1. d= Vi*t + .5at^2
2. d= Vi + at^2
This second equation is not true.
The first equation is right, but there are several more kinematic equations that would be helpful. What are they?
d= 5.5t^2
d= 11t
5300= 5.5t^2 + 11t
Your approach is not working because it looks like are trying to describe the motion all at once. However, here the acceleration is changing: first the sled has an acceleration, and later it moves with zero acceleration. The kinematic equations you are using are for constant acceleration only, so you will need to split up the motion into two parts and treat them separately. (For example, find an expression for the distance the sled travels while it is speeding up, and find a separate expression for the distance traveled while it is moving at constant speed.) What do you get?
9K
