Calculating Displacement of a Grizzly Bear: Homework Solution
  • Thread starter Thread starter deaky220
The discussion focuses on calculating the displacement of a grizzly bear that travels 1563 m due west and then 3348 m at an angle of 32.0 degrees north of west. The correct method to find the resultant displacement involves calculating the x and y components of both movements, summing them, and applying the formula for magnitude, which is the square root of the sum of the squares of the components. The final displacement magnitude is 4438 m, and the direction is determined using the inverse tangent of the y-component over the x-component, yielding an angle of 70.6 degrees relative to due east.
  • Understanding of vector components in physics
  • Knowledge of trigonometric functions, specifically inverse tangent
  • Familiarity with displacement and magnitude calculations
  • Ability to interpret angles in relation to cardinal directions
  • Review vector addition and decomposition techniques
  • Study trigonometric functions and their applications in physics
  • Learn about graphical representation of vectors
  • Explore problems involving displacement in two dimensions
Students studying physics, particularly those focusing on mechanics and vector analysis, as well as educators looking for examples of displacement calculations in real-world scenarios.
deaky220
14.In wandering, a grizzly bear makes a displacement of 1563 m due west, followed by a displacement of 3348m in a direction 32.0degrees north of west. What are a)the magnitude b) the direction of the displacement needed for the bear to return to its starting point? Specify the direction relative to due east.(pg 4 of notes)
mag=squareroot of x^2 + y^2
I took the x and y components of both vectors A and B. added them up took square root of x^2 and y^2 to get 4438 m. then took the inverse tan of 4438/1563 and got 70.6 degrees East. 2 questions i had was if my formula is correct in that the Magnitude = either the square root of x^2 + y^2 or is it just x^2 + y^2 and for the direction do i take the inverse tan of the x and y components like x over y or do i take the inverse tan of opp/adj which is 4438/1563? Thanks to anyone who can help me check my answer I have no where else to look.
Yes, you take the square root of x2+y2.
For the angle, take the inverse tan of
y-component / x-component
(That's opposite/adjacent sides, if you draw a right triangle)
And the direction can't be eastward ... the bear travels west and/or north only.
p.s. Welcome to Physics Forums!
Your method looks fine, but your answers are incorrect. What did you get for the total x-component and the total y-compnent and what exactly did you do to get them?
9K
  • · Replies 19 ·
