How Is the Maximum Temperature of an Otto Cycle Engine Calculated?
  • Thread starter Thread starter gnarkil
    Cycle Otto
The maximum temperature of an Otto cycle engine can be calculated using the relationship Tmax = (5/12)Tmin, where Tmin is the minimum temperature and gamma (γ) is defined as Cp/Cv. In this context, Cp is 5R/2 and Cv is 3R/2, with R being 8.314. The efficiency of the Otto cycle is less than that of a Carnot engine operating between the same temperature extremes, as indicated by the equation e = 1 - (Cp/Cv)^-1.
  • Understanding of the Otto cycle and its components
  • Familiarity with the ideal gas law (PV = nRT)
  • Knowledge of thermodynamic efficiency calculations
  • Basic grasp of adiabatic processes and constant-volume processes
  • Study the derivation of the Otto cycle efficiency formula
  • Learn about the Carnot cycle and its efficiency comparison with the Otto cycle
  • Explore the implications of gamma (γ) in thermodynamic calculations
  • Investigate the impact of varying specific heats on engine performance
Mechanical engineers, automotive engineers, students studying thermodynamics, and anyone interested in the performance analysis of gasoline engines.
gnarkil
Gasoline engines operate approximately on the Otto cycle, consisting of two adiabatic and two constant-volume segments. The Otto cycle for a particular engine is shown in figure below. see atchmt
1. Find the maximum temperature in terms of the minimum temperature T_min. (gamma should be part of answer, where gamma = Cp/Cv -->Cp = 5R/2,Cv = 3R/2 --> R = 8.314
2. How does the efficiency compare with that of a Carnot engine operating between the same two temperature extremes? Note: Figure neglects the intake of fuel-air and the exhaust of combustion products, which together involve essentially no net work.
e_otto < e_carnot or e_otto = e_carnot or e_otto > e_carnot?
ideal gas law, PV = nRT
otto cycle efficiency, e = 1 - (Cp/Cv)^-1 where Cp = 5R/2, Cv = 3R/2 where R = 8.314 constant
for otto cycle TV^(gamma -1) = constant where gamma = Cp/Cv
for the problem about the temperature i used the TV^(gamma - 1) = constant equation and used T_min for T and thus used the figure to determine the corresponding volume
i used a rough calculation with PV = nRT to get a general idea of temp magnitude
pt3: P = 3P_2, V = V_1/5
pt4: P = 2P_2, V = V_1
pt1: P = P_2/2, V = V_1
pt2: P = P_2, V = V_1/5
and using T = PV/nR and subbing in each pressure and volume, and holding P_2, V_1, n and R = 1, i found pt4 = T = 2, pt3 = T = 3/5, pt2 = T = 1/5, pt1 = T = 1/2, so i assumed T_min is at pt2, and that T_max is at pt4.
how do i use the TV equation using T_min and gamma to describe T_max?
no ideas?
i had another look and Tmax is at 3, and Tmin is at 1
using PV= nRT:
Tmax = PV/nR = [3P_2(V_1/5)]/nR assume n, R, P_2 and V_1 = 1
Tmin = PV/nR = [P_2/4(V_1)]/nR
so assuming n, R, P_2, V_1 = 1, then Tmax = 3/5 and Tmin = 1/4
so Tmax in terms of Tmin ---> (3/5)x = 1/4 --> x = 5/12 so Tmax = (5/12)Tmin
i'm not sure if i am correct because i need gamma in the answer, gamma = Cp/Cv
9K
