How Can the Quadratic Formula Help Solve Real-World Problems?
The discussion revolves around a real-world application of the quadratic formula in the context of a fencing problem. The original poster presents a scenario where Markita needs to determine the dimensions of a rectangular plot of land, given specific constraints on fencing and area.
  • Exploratory, Problem interpretation, Mathematical reasoning
  • Participants explore the relationship between the perimeter and area of the plot, questioning how to set up the equations based on the given constraints. There is an attempt to derive the necessary dimensions using the quadratic formula.
Some participants have provided formulas and initial steps for solving the problem, including setting up equations for perimeter and area. There is an ongoing exploration of the solutions derived from the quadratic equation, although no consensus on the final dimensions has been reached.
The problem is constrained by the requirement to use only three sides of fencing and to achieve a specific area, which raises questions about the feasibility of the solutions found. Additionally, the original poster has requested justification for the solutions, indicating a need for deeper understanding.
travishillier
Quadratic formula help ...
Heres the question ... your help is greatly needed and appreciated ...
Markita wants to fence a rectangular plot of land along side the shore of a lake. Only 3 sides must be fenced, since the lake will form the lake will form the fourth side. Markita had 100m of fencing, and she wants the plot of land to have an area of 500m^2 (squared). Find the dimensions of the plot of land, to the nearest tenth of a metre. Expalin and justify your solution.
there's thequestion , lmk what u can do to help me out ... Thx
Please don't post the same topic twice...
cookiemonster
srry won't happen again .. thx
Well, here's your formulas.
P: 100 = 2x + y [normally, perimeter would be 2x + 2y, but because one of the sides is the lake, you don't count one of the y's]
A: 500 = x*y
Now, solve the first equation for y...
y = 100 - 2x
And substitute it into the area formula...
500 = x(100 - 2x)
500 = 100x - 2x^2
2x^2 - 100x + 500 = 0
Now, you can take the above and put it into the quadratic formula...
[-b +/- sqrt(b^2-4ac)]/2a
a = 2
b = -100
c = 500
Substituting in, you get 44.3 and 5.6 as the two solutions. Now, that's x...now we need y...go back to the perimeter formula...
y = 100 - 2x
Substituting in the two numbers we found above for x, you get...
Solution 1: x = 44.3, y = 11.4
Solution 2: x = 5.6, y = 88.8
If you multiply them to check the area, you'll get around 497 and 505, which isn't exactly 500, but you were asked to give rounded values to the nearest tenth, so that's okay.
