How would you define head-on collision?
  • Context: High School
  • Thread starter Thread starter i_island0
    Collision
The discussion revolves around the definition of a "head-on collision" in physics, exploring various interpretations and terminologies associated with it. Participants examine the implications of different types of impacts, such as central, eccentric, direct, and oblique impacts, and how these relate to the concept of head-on collisions in both theoretical and practical contexts.
  • Meta-discussion
  • Some participants suggest that a head-on collision occurs when the point of impact lies on the straight line connecting the centers of gravity of the colliding objects.
  • Others argue that the definition may be more of a linguistic issue rather than a strictly physical one, with terms like "central" or "direct" being potentially interchangeable but requiring precise definitions.
  • One participant questions whether all collisions could be considered head-on if one can always connect the centers of spherical objects with a straight line, suggesting that this perspective introduces ambiguity.
  • Another participant refines the definition by stating that for a collision to be classified as head-on, the center of mass line and the velocity vectors of the objects must be parallel, with the velocity vectors pointing in opposite directions.
  • Concerns are raised about the lack of clear definitions in textbooks, leading to confusion when solving problems that reference head-on collisions without explicit definitions.
  • Some participants reference Wikipedia's definition, which focuses on the physical contact points of vehicles, suggesting that this might not adequately address the velocity direction in collisions involving spheres.
  • There is a discussion about the importance of translating everyday language into mathematical language in physics, highlighting that the lack of precise definitions in textbooks can lead to misunderstandings.
  • One participant emphasizes that the definition of head-on collision may vary depending on the frame of reference, noting that in the center of mass frame, all collisions could be viewed as head-on.
Participants do not reach a consensus on a single definition of head-on collision. Multiple competing views and interpretations remain, reflecting the complexity of the concept and its dependence on context.
Limitations include the ambiguity in definitions, the dependence on specific frames of reference, and the varying interpretations of terminology used in different contexts. The discussion highlights the need for clarity in definitions when addressing collision types in physics.
i_island0
How would you define head-on collision? I am having confusion in definition itself
Among the following, which one would you call head-on collision:
-central impact
-eccentric impact
-direct impact
-oblique impact
A head on collision means that the point of impact is on the straight line connecting the center of gravity of each of the objects. Which term describes it best is more of a language problem rather than a physics question. My off-hand guess would be central or direct, but these terms require precise definitions.
if i take any spherical ball, no matter what be the direction of velocities, i can always connect their centers with a straight line. So shouldn't i call all collisions to be head-on in that way?
Evidently then, there is at least one frame of reference (actually infinitely many) in which a collision is always head on. One of these is the centre of mass frame, which is frequently used to simplify calculations, and then the results reverted back to the lab or outside frame.
Is there any particular reason for your asking? The Physics remains the same how ever you term a collision.
With further thinking, I can see my original comment was incorrect. For a collision to be head on, three things must be parallel (sticking to spheres), the center of mass line and the velocity vectors of the two objects.
Also, velocity vectors should point in the opposite directions and need to be nonzero.
Yes, there is a reason why i am asking this. Books like irving shames and Jhonston never actually defined head on collision. When i read resnick halliday walker.. or krane.. he also never defined head on collision. But in their exercise problems.. suddenly he started making statements on head on collision.
So my problem was how do i start solving a question without knowing the definition of the terms they are making in the question.
If we read wikepedia: http://en.wikipedia.org/wiki/Head-on_collision
It says something like this: "A head-on collision is one where the front ends of two ships, trains, planes or vehicles hit each other, as opposed to a side-collision or rear-end collision".
So, if i were to accept wikepedia, then in that case i shouldn't worry about the velocity direction of the balls at all; as it is not saying anything about the velocity direction in its definition.
I think this calls more for common sense than Physics. Use the term head on collision as you would in real life. Wiki does not quite give the picture.
As has been outlined in the other posts, in the lab frame, the centres of mass of the two bodies should be traveling in the same straight line and approaching each other to call it a head on collision. You can’t make it simpler than this. (In general, in collision problems, rotations of the individual bodies are not taken into consideration explicitly, but there is no reason why it cannot be considered when the problem demands it.)
Do remember, though, that every oblique or otherwise collision is head on in the centre of mass frame when two bodies are involved. This allows us to confine the calculations to only one dimension.
What if he doesn't use English in real life? :smile:
An important part of learning physics at the introductory level is learning how to translate the description of a problem from everyday language to mathematical language. That's why textbook authors write exercises that don't use mathematically precise descriptions. This causes problems when the student doesn't understand the description because English is not his native language, or he's never had real-life experience with objects or devices that are used in the description, etc.
For example, exercises about conservation of energy (in particular kinetic energy and gravitational potential energy) often involve roller-coasters. I once had a student ask me for a detailed clarification of such an exercise because (amazingly) she had never ridden a roller-coaster! (and hadn't experienced how you speed up going downhill and slow down going uphill, etc.)
However, if the student does have the appropriate language skills and everyday-life knowledge, then... if the textbook doesn't explicitly define "head-on collision" in a mathematically precise way, I think it's safe to assume that the authors want the student to figure out the correct mathematical description himself, as part of the solution to the exercise.
I think it's an interesting query. I would say that the language semantics, for at least English, imply the following definition:
- Initial points of contact on both objects are on a point along their respective motion vectors as drawn from their respective COGs. Or, if there are multiple instantaneous points of contact, the center of resistance of those collated points lies on the motion vector of the COG.
- The respective motion vectors of the two objects are, when summed, negative. (I don't see why it would have to be 180 degrees in all planes).
The usage of "motion vectors" implies a frame of reference without explicitly saying so. For a ball, from its reference frame any collision is always "head-on" and it is trivial to say so. But not from another reference frame.
Did I mention English anywhere? Of course, you meant something broader, but if language is the problem, then I sincerely don’t think this is the right place for this discussion. But you have raised a good point and I’ll remember it in the future, noting that this confusion can also occur to a student whose native tongue is English.
I do agree with you that at this introductory stage, every new term has to be explained to the student, but he also must play ball some day in real life. The student will learn very shortly to compare gas molecules with billiard balls, and then he will have to fall back on these elementary concepts. But he or she also has to learn to correlate words from everyday-life to problems in Physics, and as you point out, this could be the reason that some authors are not so explicit.
I did mention “common sense”, which I admit maybe rather vague. However, that is exactly why immediately afterwards I have given the precise and the simplest way of explaining the concept in question to the student.
Additionally, I always found it good to explicitly state my assumptions when giving the solution so as to avoid any ambiguities in the meaning of my answer. By clearly defining what you mean by the terms you use in a problem, the reader can correctly interpret the meaning of your answer.
CS
I don't think common sense is so common... besides, if we're honest, many phrases which we use in every day life can seem obvious, but upon closer inspection it's found that we're not actually 100% sure what we're talking about...
Wow... so much philosophy.. but what is the final conclusion??
I will just write what i understood:
- head-on collision is one in which velocity vectors are directed towards each other.
- in COM frame all collisions are head-on
Unfortunately, that will be true for any science too, up to any degree of sophisticaton you choose to reach. However, this is not really the thread to discuss it.
In the frame in which the system is being studied, the CMs of the two bodies should be traveling in the same straight line. (Velocity vectors may be parallel or anti-parallel without lying on the same st. line -- Post #8.)
ok.. i got it this time.. thanks to all
  • · Replies 35 ·
