Is Lifting and Dropping a Weight Considered Doing Work?
  • Thread starter Thread starter Reverie29
    Gravity Work
The discussion centers on the concept of work in physics, specifically regarding lifting and dropping a weight. According to the equation W = F*d, work is defined as the force exerted over a distance. While lifting a weight involves positive work done by the lifter, the total work done on the weight is zero when considering both the lifting and falling phases, as the weight returns to its original position. Gravity performs work during the fall, balancing the positive work done during the lift.
  • Understanding of the work-energy principle
  • Familiarity with the equation W = F*d
  • Knowledge of scalar and vector quantities in physics
  • Basic grasp of kinetic and potential energy concepts
  • Study the work-energy theorem in detail
  • Learn about gravitational potential energy and its relation to work
  • Explore the concept of negative work and its implications
  • Investigate the role of forces in different physical scenarios
Students of physics, educators teaching mechanics, and anyone interested in understanding the principles of work and energy in physical systems.
Reverie29
I feel like I'm missing something, specifically in regard to the total amount of work. Can someone set me straight?
Suppose you lift a heavy weight from the floor to high over your head and let it fall back to the floor. An observer says you did no work because it wound up in its original position. You disagree. Who’s right?
W = F*d
Work is equal to force * distance, or in other words, the amount of force exerted over a certain distance. Work is also a scalar quantity, which makes the direction irrelevant to the problem (there are no negative or positive signs indicating the direction). All scalars are treated as positive values. Although the weight winds up in the same position, work is still done. Therefore, the total amount of work done is equal to the weight of the weight multiplied by the distance it is lifted up, in addition to when it is allowed to fall back to the floor. However, when it is lifted up, the person lifting the object is doing work. When it is left to fall, the person is no longer doing work and gravity does work pulling the object back to the ground.
Hi Reverie29,
W = F*d
The directions of the force and displacement are very important, as work can be a negative quantity. For constant forces, the work done by a force F is
[tex] W=Fd\cos\theta[/tex]
where [itex]\theta[/itex] is the angle between the directions of F and d.
The question only asked about the work that you did on the box, and I believe you got that correct.
But to add a bit to what you have written: since the block has zero kinetic energy at the beginning and ending of the motion, the total amount of work done on the block is zero. You are right that the person does positive work on the box while lifting it up, and gravity does positive work on the box while the box falls. So what else does work on the box, to make the total work be zero?
  • · Replies 19 ·
