Finding Horizontal/Vertical Tangents for x=(3t)/(1+t^3), y=(3t^2)/(1+t^3)
  • Context: Undergrad
  • Thread starter Thread starter mzmad
The discussion focuses on finding the coordinates of points where horizontal and vertical tangents occur for the parametric curve defined by x=(3t)/(1+t^3) and y=(3t^2)/(1+t^3). Participants explore the necessary derivatives and conditions for tangents, addressing both the theoretical and computational aspects of the problem.
  • Homework-related
  • One participant requests guidance on how to begin finding horizontal and vertical tangents for the given parametric equations.
  • Another suggests using the chain rule to find dy/dx, indicating the relationship between dy/dt and dx/dt.
  • Horizontal tangents are identified where dy/dx = 0, while vertical tangents occur where dy/dx is undefined.
  • Participants discuss the conditions for horizontal tangents, specifically setting the numerator of dy/dx to zero while ensuring the denominator is non-zero.
  • There is a proposal to solve for parameter values t that yield horizontal tangents, leading to specific values of t being discussed.
  • One participant emphasizes the need to find the corresponding (x,y) coordinates after determining the values of t.
  • Another participant clarifies that the tangent is defined in terms of dy/dx, not dy/dt, and suggests using the chain rule for differentiation.
  • There is a correction regarding the values of t found for horizontal tangents, with a specific focus on the nature of the roots involved.
Participants generally agree on the methods to find horizontal and vertical tangents, but there is some disagreement regarding the specific values of t that yield these tangents, particularly concerning the nature of the roots involved.
Some participants express confusion about the differentiation process and the relationship between dy/dt and dy/dx, indicating potential misunderstandings in the application of the chain rule and the conditions for tangents.
mzmad
Give the (x,y) coordinate of each point where a horizontal/vertical tangent for the curve: x=(3t)/(1+t^3), y=(3t^2)/(1+t^3). from -inf to inf.
Can someone please guide me through this?! I'm not sure where to begin.
Chain rule?
[tex]\frac{dy}{dx}[/tex] = [tex]\frac{dy}{dt}[/tex] [tex]\frac{dt}{dx}[/tex]
Horizontal tangents => dy/dx = 0
Vertical tangents => dy/dx = undef.
Horizontal Tangent: dy/dt= (3t^2)/(1+t^3)= -3t(t^3-2)/(t^3+1)^2=0. How do I solve?
Assuming you did the derivative correctly, setting the numerator equal to zero will give you the horizontal tangents as long as the denominator is a non-zero.
Setting the denominator of dy/dx equal to zero will give you an undefined slope, meaning the tangent line is vertical.
horizontal tan dy/dt=o=3t(t^3-2)/(1+t^3)^2, t=0, -2^1/3, 2^1/3.?
Looks right.
and so my coordinated would be (x,y)=(0,0), (-2^1/3,0), and (2^1/3,0)??
You solved for the parameter value t for when the derivative is 0. However x and y are both functions of t, so you still need to find x and y
ahhh, I see. (0,0)(3*2^1/3)/(1+(2^1/3)^3),0) and -3*2^1/3/(1-(2^1/3)^3),0) ?
"horizontal tan dy/dt..."
The coordinates of this curve are defined in terms of a parameter t.
The tangent to the curve is not dy/dt, it is dy/dx. To find dy/dx, there are two possibilities.
You solve one of the given equations for either x or y (depending on which equation you choose), subtitute into the other equation and get y in terms of x, then differentiate to get dy/dx. It would be messy to do so in this case.
Or, use the chain rule.
[tex]\frac{dy}{dx}[/tex] = [tex]\frac{dy}{dt}[/tex] [tex]\frac{dx}{dt}^{-1}[/tex]
= [tex]\frac{-3t^{4} + 6t}{(1 + t^{3})^{2}}[/tex] [tex]\frac{(1 + t^{3})^{2}}{-6t^{3} + 3t}[/tex] =...
Simplify and set = 0; solve for t; sub into the original equations to get (x,y).
Yes, but edziura, as you said:
[tex]\frac{dy}{dx} = \frac{\frac{dy}{dt}}{\frac{dx}{dt}}[/tex]
So you can individually solve dy/dt and dx/dt for the points of vertical and horizontal tangency.
I agree.
Now, I'm a bit confussed. What did I do wrong? I did dy/dt and dx/dt separately.
"horizontal tan dy/dt=o=3t(t^3-2)/(1+t^3)^2, t=0, -2^1/3, 2^1/3."
t = 0 and t = 2^1/3 are correct, but not t = -2^1/3; you are finding an odd root, not an even one.
  • · Replies 17 ·
  • · Replies 33 ·
