Thread Closed
Plane banking: Pitch and roll axes
Share Thread Thread Tools
Sep16-08, 08:09 PM   #1
Recognitions:
Gold Membership Gold Member
Alrighty-then
This is from a book called "Engineering by Design." It sucks. Really. It asks problems and doesn't provide sufficient information to answer them. Now that I have complained, here is the question:
Explain with sketches why a combination of rotations about the pitch and roll axes results in a plane banking through the air (with the rudder then used for slight corrections in the turn).
I am a little lost on this to say the least. I know no one can draw it out for me, but if someone could at least briefly explain the procedure, I might be able to wing it --no pun.
Does the order of the rotations matter? That is, pitch first, then roll....or the other way around? Or does it not matter?
Any clues would help
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Sep16-08, 09:22 PM   #2
If you turn the yoke on the airplane, the airplane will roll in the same direction.
This causes the lift vector to bank at the same angle as the airplane. So if the airplane is flying level, Lift= weight. When you turn, the lift in the z -axis is now only Lcos(theta).
So the plane is going to pitch down unless you correct for that by pulling back on the yoke, giving it up elevator.
Sep16-08, 09:37 PM   #3
Recognitions:
Quote by Cyrus View Post
Perfect! I was just looking at a website I found that was explaining this! But your way is much more concise.
Thanks
Thread Closed
Thread Tools
Similar Threads for: Plane banking: Pitch and roll axes
Thread Forum Replies
Pitch vs Noise? General Physics 16
Finding where the plane intersects the x,y,z axes Calculus & Beyond Homework 3
Why are pitch and frequency similiar to loudness and intensity? General Physics 3
Musical question regarding concert pitch/philosophical pitch Introductory Physics Homework 4
Variable Pitch Fans Mechanical Engineering 4
