Final Speed of Particle: 2D Motion Problem
The discussion revolves around a two-dimensional motion problem involving a particle's final speed after undergoing acceleration. The original poster presents a scenario where a particle moves with an initial velocity in the x-direction and experiences acceleration in the y-direction over a specified time period.
  • Mixed
  • Participants explore the calculation of final speed using vector addition and the Pythagorean theorem. Questions arise regarding the correctness of the resultant speed and the interpretation of acceleration in the context of the problem.
Some participants affirm the calculations presented, suggesting that the approach to finding the resultant speed is valid. Others introduce a different motion scenario, prompting questions about the calculation of displacement and the use of vectors in determining magnitude.
There are indications of potential confusion regarding the application of kinematic equations and vector addition in both scenarios. Participants are also navigating the implications of significant figures in their calculations.
blayman5
A particle moving at a velocity of 5.2 m/s in
the positive x direction is given an accelera-
tion of 5.3 m/s2 in the positive y direction for
9.9 s.
What is the final speed of the particle?
Answer in units of m/s
I multiplied the acceleration by the time to get velocity.
I found the resultant velocity between the two vectors which was 52.7. Is that the same as the final speed?
We're looking at a scenario where object's original speed in the y-direction is 0. Then they accelerated it in the y-direction, so the final speed will represent a line going diagonally through the first quadrant of a Cartesian coordinate system.
Acceleration is defined as change of speed over a period of time. So basically:
a = (vf - vi)/(change in t)
vf = at + vi = 5.3 m/s2 * 9.9s + 0 m/s = 52.47m/s <= in y-direction.
Speed in x-direction is 5.2m/s. So its a triangle with one side being 52.47m/s and the other one 5.2m/s. Using regular Pythagorean theorem, the resultant speed (the hypotenuse, essentially) is 52.73m/s. According to significant digits, the right answer should be 53m/s.
So what you found is indeed the right answer. Good job!
thanks Melawrghk
A particlemoves in the xy plane with constant
acceleration. At time zero, the particle is at
x = 6 m, y = 1.5 m, and has velocity ~vo =
(3.5 m/s) ˆı + (−6 m/s) ˆ . The acceleration is
given by ~a = (5.5 m/s2) ˆı + (6 m/s2) ˆ.
What is the magnitude of the displacement
from the origin (x = 0 m, y = 0 m) after
2.5 s? Answer in units of m
I was wondering if you have a unit vector 17.25i+9j and a starting vector of 6.18466m of the displacement vector. how could you find the magnitude of the displacement after 2.5 sec.
I found the meters off of the resultant vector by multiplying the resultant by 2.5. Then i found the magnitude of the displacements. Where did i go wrong?
  • · Replies 20 ·
  • · Replies 18 ·
  • · Replies 19 ·
