Problem with implication and bi-implication.
  • Context: Undergrad
  • Thread starter Thread starter ehj
    implication
The discussion revolves around the implications and definitions related to square roots, particularly focusing on the mathematical relationships between expressions involving square roots and their squares. Participants explore the correctness of various statements and implications, questioning the definitions and conditions under which these relationships hold.
  • Some participants express confusion over the implications of the square root function, particularly regarding the statement "sqrt(A)=B => A=B^2 <=> B=-sqrt(A) or B=sqrt(A)" and its reversibility.
  • One participant asserts that the definition of square root should clarify that "sqrt(a) is the positive real number b such that b^2 = a," which leads to discussions about the implications of this definition.
  • Another participant questions the correctness of rearranging implications, suggesting that "v=sqrt(b) => v^2=b" must hold true, while also noting that "v^2=b => v=sqrt(b)" cannot be universally true without additional conditions.
  • There is a discussion about the use of "or" versus "and" in logical statements, with some participants emphasizing the importance of distinguishing between these in the context of square roots.
  • Some participants propose that if one is only interested in positive solutions, it is mathematically correct to express relationships in a way that explicitly states the positivity condition.
Participants do not reach a consensus on the implications and definitions discussed. There are competing views on how to interpret the relationships between square roots and their squares, as well as the conditions under which certain statements hold true.
Limitations in the discussion include assumptions about the positivity of variables and the definitions of square roots, which are not universally agreed upon. The implications discussed depend heavily on these definitions and conditions.
ehj
I have a problem which is best explained with an example:
Since A=B^2 <=> B=-sqrt(A) or B=sqrt(A) I should be able to reverse the order of this into
B=-sqrt(A) or B=sqrt(A) <=> A=B^2
But if this is done in the first equation you obviously run into a problem:
sqrt(A)=B => B=-sqrt(A) or B=sqrt(A)
What is it that I'm doing wrong, what wasn't allowed in above calculation?
"sqrt(A)=B => B=-sqrt(A) or B=sqrt(A)". Notice the "or" there, if sqrt(A)=B then obviously the statement "B=-sqrt(A) or B=sqrt(A)" holds, since only one of B=-sqrt(A) or B=sqrt(A) needs to be true, and B=sqrt(A) is true...
I presume you mean "(B=-sqrt(A) or B=sqrt(A)) <=> A=B^2" and "sqrt(A)=B => (B=-sqrt(A) or B=sqrt(A))". I see nothing wrong with either of those.
okay great
HalsofIve the sqroot of 9 is 3 and not 3 or -3 but how do you guarantee that in the definition of sqroot??
If you write sqroot(A)=B <===> B^2=A ,only.... then sqroot(9)=B <===> B^2=9 <==> (B=3v B =-3) AND hence sqroot(9)= 3 or -3
So what is the proper definition of the sqroot??
The proper definition of square root is, of course, "sqrt(a) (for a a non-negative real number) is the positive real number b such that b2= a".
Now, back to the implications. Using that definition,
"(B=-sqrt(A) or B=sqrt(A)) <=> A=B^2" is correct.
The statement "sqrt(A)=B => (B=-sqrt(A) or B=sqrt(A))" is also a correct statement but has nothing to do with the definition of sqrt(A). It is true simply because "A=> (A or B)" is a tautology.
In particular, I did NOT write, nor would I, "sqrt(A)=B <===> B^2=A". That is false.
So if I have an expression, for instance a speed squared equals something, but I'm only interested in writing the positive solution, it would only be mathematically correct to write:
v^2 = b <= v=sqrt(b)
Right?
If you are only interested in the positive solution, you don't need to write "[itex]\pm[/itex]". Although I think it would be better to write v^2= b => v= sqrt(b) since the implication is going that way.
But you said earlier: "(B=-sqrt(A) or B=sqrt(A)) <=> A=B^2" is correct."
The statement "sqrt(A)=B => (B=-sqrt(A) or B=sqrt(A))" is also a correct statement"
Which gives you that sqrt(A)=B => A=B^2
If that is rearranged and B replaced with v and A with b you get:
v=sqrt(b) => v^2=b
which is the same as
v^2=b <= v=sqrt(b)
Which was what I asked about the correctness of earlier.
If what you said is also true, that v^2=b => v=sqrt(b) you have implications both ways and actually a biimplication: v^2=b <=> v=sqrt(b) which is not correct! So it has to be either.. But you seem to be giving two different answers HallsofIvy :P
v=sqrt(b) => v^2=b
v^2=b <= v=sqrt(b)
No, it is the difference between "or" and "and".
If "A is true" then "either A is true or B is true" is a tautology.
"sqrt(A)= B=> (B= -sqrt(A) and B= sqrt(A))" is a false statement: "sqrt(A)= B" does NOT give "B= -sqrt(A)".
But "sqrt(A)= B=> (B= -sqrt(A) or B= sqrt(A)" is a true statement because "sqrt(A)= B" does give "B= sqrt(A)" and so the "or" statement is true whether "B= -sqrt(A)" is true or false.
I did not and would not say "v2= b <=> v= sqrt(b)".
I would say "v2= b <=> (v= sqrt(b) or v= -sqrt(b))"
"I did not and would not say "v2= b <=> v= sqrt(b)"." I know, I didn't say you did. I completely agree with your latest post, but I don't see it's relevance? I never mentioned "and" in any of the math?
The only problem I have now is that you said that v^2=b => v=sqrt(b)
It gives rise to a problem.
Do you agree that v=sqrt(b) => v^2=b ?
This has to be correct since I'm simply squarring both sides, applying the _function_ f(x) = x^2 on both sides. By the definition of a function, it relates only one element in the codomain for each element in the domain, which makes it impossible for the second statement v^2=b to be false. So v=sqrt(b) => v^2=b has to be correct. This is the same as v^2=b <= v=sqrt(b)
You wrote in an earlier post that v^2=b => v=sqrt(b). Clearly one of these has to be wrong since we would otherwise have a biimplication between the two statements (which is wrong, like you said yourself). You agree that A => B and B => A can be put together to A <=> B right? This post seems to be very much like the last i posted :/
I think in post #9, Halls meant to switch the order of the statements, so that we don't have this awkward <= in the middle, but forgot to actually do it.
Please read ALL of post 9:
I have added the emphasis.
This was in response to post 8:
Right?
where again I have added the emphasis.
Maybe I'm reading you wrong, but assuming all is real numbers, it is always true that
v = sqrt(b) => v^2 = b
and
v = -sqrt(b) => v^2 = b
but
v^2 = b => v = +/- sqrt(b) (sqrt meaning the principle square root)
if you know that v is positive also then you of cause have
v^2 = b => v = sqrt(b).
But for it to mathematical correct it would be better to write
(v^2 = b and v > 0) => v = sqrt(b).
So you say that saying "v is positive" is like adding a condition like
v^2=b and v>0 => v=sqrt(b)
yeah or else i would write
and then as a physicist, write something like: Because of the context (of some given exercise fx.), only the positive solution makes sense so the negative is rejected.
Maybe you can even say v^2=b and v>=0 <=> v=sqrt(b)
where >= means bigger than or equal to
The plus-or-minus sign is an evil shorthand used to confuse students of algebra.
This is actually a case of abuse of the equals sign. When you see a teacher write that x^2 = 4 implies x = +/- 2, he or she means something that cannot be expressed using standard algebraic notation. He or she *means* to say that the *set of solutions* to that equation is {-2, 2}. He or she *means* to say that x = -2 OR x = 2. But it can't be both, and you cannot correctly express it using a single equals sign.
One thing that algebra teachers often neglect to teach their students is that the sqrt function is in fact NOT the inverse of squaring! The equation sqrt(x^2) = x is true sometimes, but not all the time. It's only true when x >= 0! Squaring is an operation that has no inverse. Once you square something, you can't undo it safely.
  • · Replies 22 ·
  • · Replies 31 ·
  • · Replies 22 ·
  • · Replies 19 ·
  • · Replies 131 ·
13K
