How Do Positively Charged Electrons Affect the Net Electric Field at Point P?
  • Thread starter Thread starter Aerosion
    Electron
The discussion centers on the behavior of electric fields generated by charges in a triangular arrangement, specifically addressing a scenario with charges of +2e and +e. It clarifies that electrons are negatively charged and cannot be described as +e or +2e. The net electric field at point P, located at the midpoint of the hypotenuse, is zero due to the cancellation of forces from the two positive charges, which repel a test charge equally in opposite directions. If one charge were negative, the forces would not cancel, resulting in a net electric field.
  • Understanding of electric charge and its properties
  • Familiarity with Coulomb's Law
  • Basic knowledge of electric fields and forces
  • Concept of test charges in electrostatics
  • Study Coulomb's Law and its applications in electrostatics
  • Learn about electric field lines and their significance
  • Explore the concept of superposition in electric fields
  • Investigate the effects of negative charges on electric field behavior
Students of physics, particularly those studying electrostatics, educators explaining electric fields, and anyone interested in understanding charge interactions in electric fields.
Aerosion
Okay, three electrons are arranged in a right triangle-like shape. The electron where the right angle goes is +2e, and the other electrons are +e. And at the half point of hte hypotenuse there is a point P and they want hte magnitude of the net electtric field.
They're saying that the two +es cancel out. How do they cancel out if they're both positive?
First of all, electrons are not +e charges and there is no such thing as a "+2e electron". Electrons are negatively charged particles with a charge of -e.
I assume instead of electrons there are simply 'charges' of +e and +2e, it does not matter what causes these charges.
Anyway, they cancel out because they are both positive. Suppose you have a testcharge of +1 C at point P. Also suppose one of the +e charges is called charge 1 and the other is called charge 2 (does not matter which is which).
The force the test charge feels due to charge 1 will push it away from charge 1, and hence, towards charge 2.
The force the test charge feels due to charge 2 will push it away from charge 2, and hence, towards charge 1.
The net force is therefore zero, both forces cancel each other out.
The same goes ofcourse for the electric field at point P but it is easier to explain in terms of force.
If one charge (let's say charge 1) however was negative (-e) then:
Charge 1 will attract the test charge (which is positive) towards charge 1, and away from charge 2.
Charge 2 will repel the test charge towards charge 1 aswell, so they don't cancel!
