Questions on Ferrofluid: Advantages, Delivery of Meds & Particle Sizes
  • Thread starter Thread starter jnbfive
    Ferrofluid
The discussion revolves around ferrofluids, specifically their advantages, drug delivery mechanisms, and particle sizes. Participants explore theoretical and practical aspects of ferrofluids, including comparisons between oil-based and aqueous ferrofluids, the chemistry of iron, and the implications for drug localization in medical applications.
  • Homework-related
  • Some participants propose that oil-based ferrofluids have advantages over aqueous ferrofluids, though specific benefits are not detailed.
  • There is a discussion on how medications could be attached to ferrofluids for targeted delivery, with questions about the necessary considerations for such treatments.
  • Participants inquire about the size comparison between ferrofluid nanoparticles and iron filings, with assumptions needing to be clarified.
  • Some participants express uncertainty about iron reactivity and its implications for ferrofluid efficiency, particularly regarding rust formation in aqueous ferrofluids.
  • Questions arise about the need for a magnetic source to localize ferrofluid delivery and whether this source must be inside the body.
  • There is a mention of the chemical composition of ferrofluids, specifically the presence of Fe3+ and Fe2+ ions.
  • Participants discuss the surfactant changes required for transitioning from aqueous to oil-based ferrofluids, with some confusion about the specifics of the question.
  • There is a note on the inertness of magnetite and its potential oxidation to maghemite, along with its implications for ferrofluid properties.
  • Questions are raised about the orientation of surfactant molecules in a water-in-oil dispersion and the HLB scale for solubilizing polar compounds in oily solvents.
Participants express various viewpoints on the advantages of different types of ferrofluids and the mechanisms for drug delivery, indicating that multiple competing views remain. The discussion does not reach a consensus on several technical aspects, including the specifics of iron reactivity and the necessary conditions for effective drug localization.
Limitations include assumptions about the size of iron filings and the chemical behavior of iron in different environments. The discussion also highlights the need for clarity regarding the chemical composition and surfactant requirements for ferrofluids.
jnbfive
I recently did a lab report on ferrofluid for chemistry and am having difficulty with some questions. I was wondering if I could get some help.
*Are there advantages to an oil-based ferrofluid compared to an aqueous ferrofluid?
*Researchers have explored ways to attach medications to ferrofluid to deliver drugs to specific locations in the body. Explain how this would work. What are some considerations that need to be made in order to undergo these types of treatments?
*If the diameter of the average ferrofluid nanoparticle is 100 nm, how many times larger is an iron filing. Include the assumptions that you use in your answer.
Many thanks to whoever can help me out.
What do you know about iron reactivity?
I would say "yes".
How might you localize the delivery of something that is magnetic?
What is the first assumption you should make regarding iron filings?
Are you asking how iron reacts with different ions in general or something different? I'm apologize for not understanding the question, but I'm quite awful when it comes to chemistry.
chemisttree said:
I would say "yes".
To localize the delivery, wouldn't you need an actual magnetic piece or magnetic attraction for the ferrofluid to be attracted to? Like something that's magnetic so it attracts the ferrofluid yet dissolvable so it doesn't need to remain in the body?
First assumption about iron filings is that they're visible to the naked eye. Do you mean relate it to what the eye can visibly see vs. what it can't i.e. something that's looks like a tiny crumb vs. something that's 1 E^-7 in size?
But you know that iron rusts!
Would it need to be inside the body to attract the ferrofluid?
mgb_phys said:
But you know that iron rusts!Would it need to be inside the body to attract the ferrofluid?
Wow, I feel stupid. Aqueous ferrofluid would result in rust, thereby making the ferrofluid inefficient.
I suppose not. A magnet could be placed in the area of the region outside of the body that the ferrofluid needs to enter, just depends on how strong the attraction would be in order to not damage any vital organs.
Exactly, and even very strong B fields eg. an NMR have no adverse effects on the body.
Couple of other questions.
1) This is just to make sure that I answered this question correctly, but in the ferrofluid, there are two ions of Fe 3+ and one ion of Fe 2+ present, correct?
2) Having a bit of difficulty understanding this question:
*You prepared aqueous ferrofluid, but the ferrofluid that is often commercially sold is an oil-based ferrofluid. Describe what changes you would need to make in the surfactant for an oil-based ferrofluid.
Again, any help is greatly appreciated.
The question claims " the surfactant " , is the question asking that the aqueous version be incorporated into an oil solution?
Except that magnetite is fairly inert. It is used as a means of preventing steel from corroding. It is supposedly possible to oxidize nanoscale magnetite (Fe3O4), like that used this lab, into maghemite (Fe2O3), but it isn't a natural occurring process in ferrofluids. Scientist are experimenting with ways to do so because maghemite has useful properties as a semiconductor. Even if the magnetite was oxidized into maghemite, it shouldn't matter because maghemite is also paramagnetic.
For a water-in-oil dispersion, the polar head would be aimed where? How about the nonpolar tail? Which direction on the HLB scale would you go to solubilize a polar compound in an oily solvent?
  • · Replies 18 ·
19K
