How does temperature affect the rate of pepsin digestion in egg albumin?
  • Thread starter Thread starter LilaK
    Biology
The discussion centers around an experiment investigating how temperature affects the rate of pepsin digestion of egg albumin. Participants explore various aspects of the experimental design, including hypotheses, methods, and the implications of results that were not collected properly.
  • Homework-related
  • One participant proposes a hypothesis that varying temperature will change the rate of pepsin digestion of egg albumin, suggesting that optimal digestion occurs around 35 degrees Celsius.
  • Another participant questions how the original experiment was deemed unsuccessful and emphasizes that unexpected results can still provide valuable insights.
  • Concerns are raised about the fairness of the experiment, particularly regarding the timing of observations and whether all samples were treated consistently.
  • Suggestions are made to refine predictions and clarify expected outcomes based on the hypothesis, particularly what results would indicate if the hypothesis is correct.
  • Participants discuss the importance of considering alternative interpretations of the results, including the impact of stopping the reaction at different times.
Participants express differing views on the fairness of the experiment and the interpretation of results. There is no consensus on the conclusions to be drawn from the incomplete data, and multiple perspectives on how to approach the lab report are presented.
Limitations include the lack of collected data, potential variability in timing of observations, and the need for clearer definitions of what constitutes a fair test in this context.
LilaK
I have to write up a lab related to pepsin. I did an experiment in class but unfortunately it did not turn out how I wanted it to be and I did not collect my results properly. Maybe someone has done a pepsin experiment before and could help me out.
This is what I thought of for my new experiment but I don't have results. Its just an idea but please give me another pepsin related experiment if you can.Aim of the experiment:
The aim of this experiment is to test whether temperature affects the rate of which pepsin reacts to egg albumin (Source of protein).
Hypothesis:
“If the temperature varies, then the rate at which the pepsin digests egg albumin will change”.
Variables:
Independent Variable – Temperature range.
Dependent Variable – Rate at which the pepsin digests the egg albumin.
Constant Variables – amount of pepsin, amount of rare egg white, amount of acid, temperature, stopwatch.
How did you determine the experiment did not turn out right? The most important lesson you might ever learn about science is that experiments don't always turn out as expected. That doesn't mean they didn't work.
Are you expected to write up your lab report on your ACTUAL results? If so, post a summary of those here so you can get proper help.
Prediction:
In this experiment I declare that my hypothesis will be true, as indeed the egg albumin will be influenced by temperature. This experiment should function to it’s best in the water bath which is situated around 35 degrees Celsius. The reason for this is due to the fact that the body temperature is situated around that same temperature, and which pepsin functions at its optimum best in. Method:
I have created a procedure of which allows me to test the effect of temperature on the rate of digestion of pepsin upon egg albumin. The four varied temperature are the following:
Ice temperature (0-5 degrees Celsius):
Boiling (90 degrees Celsius):
Water bath (37 degrees Celsius):
Room temperature (20 degrees Celsius):
I just need a rough idea of what the results would be because I was not able to collect them because I made the observations too late so it would not have been a fair test. I also need to have an idea what the conclusion for this experiment should be. Please help me out, I would really appreciate it.
LilaK said:
Prediction:
First, you need to work on refining your predictions. The second sentence there is closest to what a prediction should be, but you need to make it clearer of what you'd expect if your hypothesis is true. What do you mean by "This experiment should function to its best...?" If 35 degrees is optimal, what would your results look like?
Method:
I still don't understand why you think it's not fair? Did you let them all run the same amount of time? If so, it was fair. It's only a problem if you stopped them at different times and introduced more than one variable (time and temperature). Otherwise, you still have results to work with.
I think that's what you're supposed to be learning to figure out on your own. Here are some hints.
If you have good reason to think you'd get different results if you stopped the reaction sooner, then explain that in your discussion. You still should work with the actual results you got until then. Consider all your options, and discuss them one at a time as possible interpretations. One of those interpretations might be the one you're talking about here, that the reaction went too long and you didn't get any differences because of it. What's another interpretation? The primary conclusion should be based on the results you really got. Does it fit your prediction or not? (This is why writing a good hypothesis and prediction is important...it makes it a lot easier to draw a conclusion when done.)
Yes, in the real world of science, you would repeat the experiment while systematically changing other conditions, such as time in addition to temperature to see if there is a time dependence. But that's not what you did for the class. For a class project, your conclusions should be based just on what you were assigned to do, and just discuss any alternative interpretations to show you're thinking about those other variables too.
16K
