Need help proving Order of a formula
  • Context: Graduate
  • Thread starter Thread starter Gear2d
    Formula
The discussion revolves around proving the order of a formula using Big O notation, specifically for the expression 5n^2*lg(n) + 20nsqrt(n) + lg^3(n) + 100/n. Participants are examining the application of various rules and theorems related to asymptotic notation.
  • Post 1 presents an initial attempt to prove that the expression is O(n^2 * lg(n)), outlining several steps based on different rules of Big O notation.
  • Participants discuss the correctness of specific steps, particularly focusing on the terms 20nsqrt(n), lg^3(n), and 100/n, with some asserting that these terms are O(n^1.5) and thus less significant than the leading term.
  • There is a request for clarification on the relevance of the leading term and the interpretation of terms in the context of Big O notation.
  • One participant notes that logarithmic terms grow slower than polynomial terms, suggesting that the first term is the only one that significantly affects the overall order.
  • Concerns are raised about the accuracy of step 4, with one participant affirming that while it is correct, it is somewhat loose in its estimation.
Participants generally agree on the correctness of steps 3 and 5, but there is uncertainty regarding the relevance of other terms and the interpretation of the leading term. The discussion remains unresolved regarding the overall proof and the significance of each term in the expression.
Some participants express uncertainty about the tightness of the bounds for certain terms and the implications of logarithmic growth compared to polynomial growth. There is also a mention of the potential for multiple interpretations of the relevance of terms in the context of Big O notation.
Gear2d
I have this problem which says:
Show using rules of Theorem how to find the O notation of: (Note lg = log based 2)
5n^2*lg(n) + 20nsqrt(n) + lg^3(n) + 100/n = O(n^2 * lg(n) )
here is a link of the theorems:
http://www.augustana.ca/~hackw/csc210/exhibit/chap04/bigOhRules.html
This is what I tried to do to prove that it is O(n^2 * lg(n) ):
1) lg(n) => O(n) or O(lg(n)) [ depends if you look at Comparison Rule 2 or Log of a Power Rule]
2) 5n^2 => O(n^2)
steps 1 and 2 combined give O(n^2 * lg(n))
Steps 3, 4 and 5 I am not sure if I am right
3) 20nsqrt(n) = 20n^(3/2) => O(n^(3/2))
4) lg^3(n) => O(n) [Comparison Rule 2]
5) 100/n => O(1/n) [complete guess here]
6) Using Sum Rule and Polynomial Rule:
O(n^2 * lg(n) + n^(3/2) + n + 1/n ) = O(n^2 * lg(n))
I do not fill comfortable with steps 3 to 5 with the orders. Are all the steps correct?
3 and 5 are correct -- they seem to be the easiest steps in the whole thing! All terms other than the first are O(n^1.5) which is less than O(n^2), so only the first term is relevant.
Thank You CRGreathouse for the feedback. I was wondering could you explain what you mean when you wrote "the first are O(n^1.5) which is less than O(n^2), so only the first term is relevant"?
When you say O(n^1.5) you are referring to 20n*sqrt(n), and when you say "first term" you mean 20n is only relevant? If so, can you explain why? I thought if you had say 20x * x wouldn't this be 20x^2 = O(x^2) then?
Also, is step 4 ok, I was not sure if that was correct?
I wrote that all terms *other* than the first are O(n^1.5). In particular:
20nsqrt(n) is O(n^1.5) -- this is tight
lg^3(n) is O(n^1.5)
100/n is O(n^1.5)
The first term, the only one that matters, is 5n^2*lg(n). "Terms" are things separated by a + or -; you can't split 5n^2 from lg n since they're multiplied together.Step 4 is correct, though rather loose. Logarithms make things tiny, so in fact your function is much less than n. But it certainly doesn't grow faster than n, so O(n) is correct. O(n^0.5) or even O(n^0.000000000000001) would also be correct.
  • · Replies 21 ·
  • · Replies 25 ·
  • · Replies 17 ·
