Is the Magnitude of Proton's Acceleration Constant?
The discussion centers on the acceleration of a proton, defined by the equation a = CvxB, where a is the acceleration vector, v is the velocity vector, B is the magnetic field vector, and C is a constant. It is established that while the direction of the velocity changes due to the magnetic field, the magnitude of both the velocity and acceleration remains constant. The key conclusion is that the scalar product of acceleration and velocity is zero, indicating that no work is done on the proton, thus preserving its kinetic energy.
  • Understanding of vector calculus, specifically cross products
  • Familiarity with the concepts of magnetic fields and forces
  • Knowledge of kinetic energy and work-energy principles
  • Basic proficiency in differential calculus
  • Study the properties of vector cross products in physics
  • Explore the implications of magnetic forces on charged particles
  • Learn about the conservation of kinetic energy in electromagnetic fields
  • Investigate the mathematical derivation of the Lorentz force law
Students and professionals in physics, particularly those focusing on electromagnetism, as well as educators seeking to deepen their understanding of particle dynamics in magnetic fields.
subwaybusker
A proton has the acceleration a=CvxB, where a is the cross product of v and B (a,v,B are vectors). C is a constant and the magnetic field is constant. Prove that the magnitude of the v and a are constant.
I know I have to somehow prove the derivative of a or v to be zero, but i have no idea how to start. i know if v is constant, then a must be 0.
a=CvxB
(da/dt)=C(dv/dt)xB
i also wrote down |a|=|Cv||B|sintheta, but that doesn't help at all.
If the acceleration is the vector product of the velocity and something else, the acceleration is at right angles to the velocity. The scalar product of acceleration and velocity must then be zero. (The scalar product of two vectors is the product of their magnitudes and the cosine of the angle between them. Cosine of 90 degrees is zero.) But this scalar product is the power per kilogram (work per kilogram per second) delivered by the force.
The derivative to time of the velocity is not zero; it is the acceleration. But it merely changes the direction of the velocity in this case, not its magnitude. So the kinetic energy does not change, and no work is done.
solved it, thanks!
  • · Replies 42 ·
  • · Replies 69 ·
