How Do You Calculate the Damping Coefficient of a Pendulum in Water?
  • Thread starter Thread starter math111
    Coefficient
The discussion focuses on calculating the damping coefficient (C) of a pendulum submerged in water, given parameters such as mass (M=1kg), length (L=1.0m), and period (T=2.02sec). The equation of motion is defined as θ'' + (c/m)θ' + (g/l)θ = 0, where g represents gravitational acceleration. Participants emphasize the importance of using the correct equations and methods to derive the damping coefficient, rather than relying on unrelated formulas like the half-life equation T(1/2) = LN(2)/λ.
  • Understanding of differential equations, specifically second-order linear equations.
  • Familiarity with pendulum dynamics and the effects of damping in oscillatory systems.
  • Knowledge of gravitational acceleration (g) and its role in pendulum motion.
  • Basic proficiency in mathematical notation, including the use of θ (theta) and λ (lambda).
  • Research methods for solving second-order linear differential equations, particularly in the context of damped oscillations.
  • Explore the relationship between damping coefficients and oscillation periods in fluid environments.
  • Learn about the physical principles governing pendulum motion in different mediums, such as water.
  • Study the derivation and application of the natural frequency (Wn = sqrt(g/L)) in damped systems.
Students and professionals in physics, engineering, and applied mathematics who are interested in understanding the dynamics of damped oscillatory systems, particularly pendulums in fluid environments.
math111
I am giving M=1kg, L=1.0m, T(period) = 2.02sec. I need to find C
The pendulum is in water.
The eq of motion is double-dot-theta+(c/m)single-dot-theta+(g/l)theta = 0
I was doing some research and found this half life formula...T(1/2) = LN(2)/ Lamda. I am not sure where to go from here...
I know Wn = sqrt(g/L)...
The eq of motion is θ'' + (c/m)θ' + (g/l)θ = 0
I was doing some research and found this half life formula...T(1/2) = LN(2)/λ. I am not sure where to go from here...
Hi math111! :smile:
(have a theta: θ and a lamda: λ and use ' instead of dot :smile:)
hmm … I'm don't think that T(1/2) is the same T that you were given. :confused:
It is not a good idea to trawl the web looking for an equation that might fit. :frown:
Hint: do you know any method of solving θ'' + (c/m)θ' + (g/l)θ = 0 ? :smile:
  • · Replies 20 ·
  • · Replies 32 ·
  • · Replies 21 ·
  • · Replies 17 ·
