Question on a step in my proof.
  • Thread starter Thread starter Diffy
    Proof
The discussion revolves around proving the equality |a - b| = |-(a - b)| within the context of absolute value properties in mathematics. Participants explore the definitions and implications of absolute values, particularly focusing on the relationship between a number and its negation.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the necessity of breaking down the proof into cases based on the sign of (a - b). Some suggest that proving |x| = |-x| might be a more straightforward approach. Others question the validity of using certain definitions and symbols in the proof process.
The discussion is active, with participants providing feedback on each other's reasoning and definitions. Some guidance has been offered regarding the use of absolute value definitions, and there is an acknowledgment of the need for clarity in proofs. Multiple interpretations of the problem are being explored.
Participants note that the definitions of absolute value being used may not be universally accepted, and there is a recognition of the importance of rigor in mathematical proofs. Some participants express uncertainty about their definitions and seek clarification on the implications of their reasoning.
Diffy
I don;t think the actual problem I am trying to prove is relevant. But I have got to a step in my proof where I must show that | a - b | = | -(a - b)|
So by definition
|a - b| = +/- (a-b)
and |-(a - b)| = +/- (- (a - b)) = +/- (a-b)
Thus the two are equal.
Is this acceptable?
Or do I really need to break it down into cases where a - b is Positive negative or 0?
Thanks.
|a-b|=+/-(a-b) is NOT the definition of absolute value. The definition of |a-b| is that it is (a-b) if a-b>=0 and -(a-b) if a-b<0. You do need to break it into cases. But it's easier to prove |x|=|-x| (by cases) and then set x=a-b.
Got it, yes, I realize I can say |a-b| is greater than or equal to +/- (a-b).
but certainly not equal.
I showed that |x| = |-x| as follows:
case x>0:
If x > 0 then |x| = x by definition. If x>0 then -x<0 since x and -x can't both be in R+. if -x < 0 then |-x| = -(-x) = x
case x = 0. If x = 0 then -x = 0 and |x| = |0| = 0 and |-x| = |0| = 0.
case x < 0. If x<0 then |x| = -x by definition. If x<0 then -x>0 since x and -x can both be in R+. since -x>0, |-x| = -x and we are done.
case x>0:
That proof is just fine. If you know |ab|=|a||b|, you can also prove it by |-x|=|(-1)*x|=|-1|*|x|=|x|.
Diffy said:
… I have got to a step in my proof where I must show that | a - b | = | -(a - b)|
So by definition
|a - b| = +/- (a-b)
Is this acceptable?
Hi Diffy! :smile:
If your main proof required you to show that |a - b| = |b - a|,
then I would say that it is enough to say (a - b) = -(b - a), and therefore |a - b| = |b - a|.
But to show that | a - b | = | -(a - b)|, in that form, doesn't ssem to me to require any proof … |x| = |-x| is part of the definition of ||. :smile:
(btw, using the symbol +/-, or even ±, would not be acceptable … you should use something more rigorous, like √(x2), or sup{x,-x}, or write the concept out in English :wink:)
That sounds a little funny. If a<b then -a>-b. That's why x<0 implies -x>0.
Dick, there was a mistake,
It should say if x<0 then -x>0 since x and -x can't both be in R+.
I don't have that if a<b then -a>-b anywhere, but I do have in the my order property that only one of the following is true:
a in R+
a = 0
-a in R+
I was attempting to use that. Thanks a lot for your help dick!
Hey TinyTim,
It wasn't immediately clear (at least to me) from my definition so I felt the need to prove it.
I had:
|a| = a if a>0
|a| = 0 if a = 0
|a| = -a if a < 0
Thanks for your help Tiny-Tim!
a in R+
a = 0
-a in R+
Ok. That makes sense.
Diffy said:
Hey TinyTim,
I had:
|a| = a if a>0
|a| = 0 if a = 0
|a| = -a if a < 0
Yes, that method's fine! :smile:
  • · Replies 20 ·
