Achieving Variable Phase Shift in Yellow Light
The discussion focuses on achieving a variable phase shift in yellow light (580 nanometers) using voltage modulation. The desired modulation frequency is approximately ten megahertz, with a minimum phase shift of two wavelengths. Participants suggest exploring the use of a phase plate as a potential solution for this optical challenge. The conversation highlights the technical difficulties encountered, particularly with precision in measurements.
  • Understanding of optical phase modulation techniques
  • Familiarity with phase plates and their applications
  • Knowledge of light wavelength properties, specifically for yellow light (580 nm)
  • Basic principles of voltage control in optical devices
  • Research phase plate design and its effectiveness in optical applications
  • Explore voltage modulation techniques for optical phase shifting
  • Investigate the properties of yellow light and its interaction with various materials
  • Study modulation frequency effects on phase shift in optical systems
Optical engineers, physicists, and researchers working on light modulation techniques and applications in photonics.
Pfft
I would like to cause a phase shift in light. I would prefer to do
so by varying the voltage to the phase shift device. Is there any existing
system or any suggestions?
We had a bit of difficulty with this one. I dropped a few decimal points or something.
Lets try this one more time. I am looking for a technique to cause a variable phase shift or delay in a yellow (580 nanometer) light beam. The modulation frequency is in the order of ten megahertz, the shift need only be a minimum of two wavelengths of the yellow light.
  • · Replies 41 ·
9K
