Why: Why Does Water Freeze at 32 Deg F?
  • Context: High School
  • Thread starter Thread starter 5-StarPlayer
    Water
The freezing point of water is established at 32 degrees Fahrenheit, despite water reaching its maximum density at 39 degrees Fahrenheit under standard temperature and pressure (STP). This phenomenon is attributed to the unique molecular behavior of H2O, where density decreases as water freezes. At extreme pressures, such as those found in planetary ice bodies, ice VII becomes denser with decreasing temperature, contrasting with ice I, which is less dense under increasing pressure. The negative Clapeyron slope of ice I is crucial for its buoyancy, allowing it to float on water, a vital characteristic for sustaining life.
  • Understanding of molecular behavior of water (H2O)
  • Familiarity with phase diagrams, specifically the phase diagram of H2O
  • Knowledge of Clapeyron slope and its implications in phase transitions
  • Basic concepts of pressure effects on ice polymorphs
  • Research the phase diagram of H2O for a deeper understanding of water's properties
  • Study the differences between ice I and ice VII, focusing on their structural properties
  • Explore the implications of the Clapeyron slope in various materials
  • Investigate the role of ice in ecological systems and its importance for life
Students of chemistry, environmental scientists, and anyone interested in the physical properties of water and its significance in ecological systems.
5-StarPlayer
Why it is stated that 32 deg F is the freezing point of water when we know that water at STP (standard temperature and pressure) reaches maximum density at 39 deg F??
Thanks in advance for taking the time to answer this...
5-
Its because water is a strange substance. Due to the molecular behavior of H2O it actually reaches its greatest density slightly above freezing. Past that point the density decreases and decreases even further freezing.
This is true of water at typical pressures we find at surface conditions; but at extreme pressures (such as those found at depth on a planetary ice body) water ice does get a lot denser as temperature is reduced and pressure is increased, check out the phase diagram of H2O: http://www.es.ucl.ac.uk/research/pig/images/ice_phase_diagram.jpg.
Ice VII gets harder to melt at increasing pressures (it has a positive Clapeyron slope) whereas ice I (the stuff we're used to on Earth) actually gets easier to melt at increasing pressure - they're exactly the same substance chemically, yet they have different mineralogical structural properties (they are "polymorphs"). Interestingly, the fact that ice I has a negative Clapeyron slope is the reason that ice floats on water, which turns out to be essential for life as we know it.
  • · Replies 16 ·
9K
  • · Replies 17 ·
  • · Replies 16 ·
  • · Replies 20 ·
35K
  • · Replies 45 ·
33K
