Calculating Wave Packet Length & Frequency for Radar Transmitter
The discussion focuses on calculating the wave packet length and frequency for a radar transmitter used to measure the speed of pitched baseballs. The wave packet length is determined to be 75 meters, calculated using the formula L = c*t, where c is the speed of light and t is the pulse duration of 0.25 microseconds. The receiver should be tuned to the phase frequency, calculated as c/0.02m, while the group frequency is derived from the modulation wave at 1/(0.25 microseconds). The bandwidth is related to the spread of angular frequency, with dt being the pulse duration.
  • Understanding of wave mechanics and radar technology
  • Familiarity with frequency and wavelength calculations
  • Knowledge of pulse duration in electromagnetic waves
  • Basic principles of bandwidth and angular frequency
  • Study the relationship between wavelength and frequency in electromagnetic waves
  • Learn about radar signal processing techniques
  • Research the concept of group and phase velocity in wave packets
  • Explore bandwidth calculations in communication systems
Students in physics or engineering, radar technology enthusiasts, and professionals involved in signal processing and telecommunications.
EngageEngage
A radar transmitter used to measure the speed of pitched baseballs emits pulses of 2.0cm wavelength that are .25micros in duration.
(a) what is the length of the wave packet produced?
(b)to what frequency should the receiver be tuned?
(c) What must be the minimum bandwidth of the receiver
I think I have (a) right: Length of the wave packet is the time of the pulse times the speed of the wave.
L=c*t = 75m.
(b) This is what I'm not sure on. Must the receiver be tuned for the group frequency or the phase frequency? If I'm thinking about this right, these pulses should make beats.
The group frequency will be: 1/(.25micros), right? This is the frequency of the modulation wave.
The phase frequency would be c/.02m, right? This is the frequency of the wave 'inside' the modulation wave.
Or am I completely misunderstanding the problem?
(c) The bandwidth, if I am not mistaken is dw, (spread of angular frequency).
dw*dt~1
Would dt here just be the .25micros?
If anyone could tell me if I am doing this right and help me out, I would appreciate it.
(b) The receiver is tuned for phase frequency.
(c) Correct -- might be an extra factor of pi or 2*pi, I'm not sure about the exact relation.
thank you for the help
  • · Replies 39 ·
  • · Replies 68 ·
