What is the purpose of a dual adjustable DC power supply and how does it work?
The discussion revolves around the purpose and functionality of dual adjustable DC power supplies, focusing on their terminal configurations and voltage outputs. Participants explore how to properly connect the terminals and the implications of using ground versus negative terminals in various scenarios.
  • One participant questions the voltage output when connecting a dual adjustable DC power supply, asking if the voltage across the wires would be 30 volts or 60 volts when using the + and - terminals.
  • Another participant explains that the ground serves as a voltage reference and can be connected to the negative terminal, allowing the positive terminal to be at a specified voltage with respect to ground.
  • A participant outlines different cases of connecting resistors to the power supply, attempting to clarify the expected voltage across the resistors in various configurations.
  • There is a mention of the common terminal in dual adjustable supplies, which is not necessarily Earth ground, and its role in providing positive and negative voltages for applications like operational amplifiers.
Participants express varying levels of understanding regarding the connections and voltage outputs of the power supply. Some agree on the function of the ground as a reference point, while others remain uncertain about specific configurations and their implications.
There are unresolved questions about the exact behavior of the power supply in different configurations, particularly regarding the voltage readings and the role of the ground terminal versus the negative terminal.
fisico30
hello ,
DC (I guess AC too) power supplies have 3 terminals: plus, ground, minus.
If I set the voltage to 30 Volts, and plug one cable in the + terminal and the other in the - terminal, is the voltage across the wires 30 volts or 60 volts? When do we use the ground or the negative?
I tried with one powersupply and it gave me 60...
thanks!
The ground is provided for a voltage reference -- it's the same as the Earth ground in the wall socket the power supply is plugged into. This is useful when you need to connect several pieces of equipment together and want them to share the same ground potential.
A typical application is to connect the - and ground terminals together, forcing the negative terminal to ground. The + terminal is then at 30V with respect to Earth ground.
Alternatively, you could connect the + and ground terminals together, and the - terminal would be at -30V with respect to Earth ground.
If you don't care at all what absolute voltages exist in your circuit with respect to ground (say, your circuit is battery powered), there may be no reason to use the ground terminal at all.
- Warren
Thank you Warren. You are very clear.
Let me make sure I get it however:
Case 1: if the power supply is set to 10V and I connected to a resistor (2 ohms) using the + and the - terminals, the voltage across the resistor should be 10V.
Case 2: if I used the + and the GRD, then the voltage on the resistor is still 10V.
Case 3: if I connect the - and the GRD together and use it as a single terminal, then the voltage across the resistor is 10V of course..Case4: IF I had 2 resistors: one resistor connected to + and - and the other to - and GRD, the voltage across the two resistors ( between the + and -), would be 20V
Do i get it or am i still confused?
thanks!
fisico30 said:
hello ,
thanks!
You're lookin at a lab supply. Did you find an old Lambda? The guys in the
Engineering|Electronics section would have told you. It's a dual adjustable DC power supply. The center tap you're calling ground is common. It's not necessarily Earth ground. The leg measured from (+) to common gives you the voltage read on the built-in meter if there is one. If it's a dual tracking supply, if you short one side, say, the other side will follow.
The idea behind such supplies is to give you the positive and negative voltages useful for biasing operational amplifiers and other stuff like them.
