How Does Charge Distribution Affect Electric Field Intensity at the Origin?
The discussion revolves around determining the net electric field intensity at the origin due to two uniformly charged rods, one placed along the x-axis and the other along the y-axis. Participants explore the implications of charge distribution and the geometry of the setup in the context of electric fields.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the relationship between electric field intensity and charge distribution, questioning whether the electric field can be treated similarly to that of point charges. There are attempts to clarify the contributions of each rod to the net electric field and whether they cancel out at the origin. Some participants suggest breaking the rods into segments for integration to find the total electric field.
The discussion is active, with participants exploring different interpretations of the problem. Some have provided hints about integrating to find the electric field contributions, while others express confusion regarding the mathematical aspects, particularly integration and antiderivatives. There is no explicit consensus on the approach yet, but guidance has been offered regarding the need to consider vector components and the integration process.
Participants are working under the assumption that the rods are parallel to their respective axes. There is mention of a missing diagram that could clarify the setup further. Some participants express uncertainty about their mathematical skills, particularly in integration, which may affect their ability to progress in the discussion.
SilverGirl
A rod of length l with a uniform charge per unit length lambda is placed a distance d from the origin along the x axis. A similar rod with the same charge is placed along the y axis. Determine the net electric field intensity at the origin.
Electric Field Intensity is the same as electric field, right? So you would use E=kq/r^2 (substituting d in for r?)
lambda = Q/l
I am under the impression the net electric field will be zero, as the charge on the x-axis should cancel out the charge on the y axis, right? Or since the rods are d away from the origin, and not actually on the origin, does this automatically mean the field is zero?
That equation is for the field from a point charge, not a line of charge. Hint: Break the line into segments and add up each of their contributions to the field. You'll have to integrate.
No. If the line charges where on opposite sides of the origin, then you could conclude that their fields would cancel out at the origin. But that's not the case here.
You'll need to find the field contribution from each line charge and then add them up. Don't forget that electric field is a vector.
The fields on the x and y are the same though right? So I find one, and can multiply it by 2?
So dE = kdq/r^2 ?? r^2 being l^2 + d^2 ?
So dE=(klambda*dl)/(l^2 + d^2)
The magnitudes are the same, but they have different directions. (So you can't just multiply by 2 to get their total.)
So the components for the x and y-axis are the same in magnitude, but opposite direction? So once you get the components for the one rod, you are able to just change the direction to find the other?
I feel so confused. Right now I have for the rod on the y axis:
Ex = k*lambda*x*(1/x^2)(sinA)(limit A1-A2)
Ex = (k*lambda)/x *{[(l+d)/SQRT(l^2+d^2)] - -(l+d)/SQRT(l^2+d^2)]
Ex = [2k*lambda*(l+d)]/[x * SQRT(l^2+d^2]
Can we assume that this rod is parallel to the x-axis (actually, directly along the x-axis), not perpendicular to it?
The picture which I did not include (sorry about that), shows both rods directly on their respective axis
Good, as I had imagined it. The differential field element from a segment dx, ignoring signs, would be given by:
[tex]dE = \frac{k \lambda}{x^2} dx[/tex]
Take the integral over the proper limits, from x = d to d + l.
Thanks very much. I have never done intergration before, so I am not really sure what it means and how to do it. Do you take out the k*lambda/x^2 first?
The k*lambda is a constant, so it just tags along. What's the integral (anti-derivative) of 1/x^2?
I have done derivatives before, but never antiderivatives before and am not sure. Just giving a wild guess would be, x ?
An anti-derivative of a function f(x) is simply a function g(x) such that when it is differentiated, it gives you f(x). So in this case, the question becomes: What must you differentiate in order to give you 1/x^2?
There's nothing wrong with guessing an antiderivative, but then you must immediately check if your guess was correct by taking the derivative. Try it.
  • · Replies 68 ·
9K
