Potential inside (and outside) a charged spherical shell
The discussion revolves around calculating the electric potential both inside and outside a uniformly charged spherical shell using a specified integral approach. The problem involves understanding the implications of spherical symmetry and the nature of surface charge density.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the application of the integral for potential calculation, questioning the treatment of the distance |x - x'| and the integration limits. There is exploration of the implications of using surface charge density versus volume charge density.
Several participants have contributed to clarifying the integral setup and the nature of the charge distribution. Some have identified potential misunderstandings in the integration process, while others have noted the need to consider different cases for the potential based on the position relative to the spherical shell.
Participants are working under the constraint of using a specific integral form as stated in the homework prompt, which may limit the methods they can employ. There is also an acknowledgment of the challenges posed by the surface charge nature of the problem.
russdot
[solved] Potential inside (and outside) a charged spherical shell
Use the integral (i) to determine the potential V(x) both inside and outside a uniformly charge spherical surface, with total charge Q and radius R.
(i) V([tex]\vec{x}[/tex]) = [tex]\frac{1}{4\pi\epsilon_{0}}\int\frac{\rho(\vec{x'})d^{3}x'}{|\vec{x}-\vec{x'}|}[/tex]
[tex]\rho(\vec{x'}) = \frac{Q}{4\pi R^{2}}[/tex]
if the x vector is along the z axis (can exploit spherical symmetry), then |x-x'| = [tex]\sqrt{x^{2} + R^{2} - 2xRcos\theta}[/tex]. (using cosine law)
Then
V([tex]\vec{x}[/tex]) = [tex]\frac{1}{4\pi\epsilon_{0}}\frac{Q}{2}\int_{0}^{\pi}\frac{sin\theta d\theta}{\sqrt{x^{2} + R^{2} - 2xRcos\theta}}[/tex]
V(x) = [tex]\frac{Q}{4\pi\epsilon_{0}x}[/tex]
or
V(r) = [tex]\frac{Q}{4\pi\epsilon_{0}r}[/tex]
Which is correct for outside the spherical shell, but I can't figure out how |x - x'| would be any different (or what else should be different) for inside the spherical shell to get
V(r) = [tex]\frac{Q}{4\pi\epsilon_{0}R}[/tex]
I realize there are better/easier ways of doing this, but the question says to use that integral specifically...
Shouldn't you have:
[tex]V(x)=\frac{1}{4\pi\epsilon_{0}}\frac{Q}{2} \int_0^{x} \int_{0}^{\pi }\frac{sin \theta ' dx' d \theta '}{\sqrt{(x')^{2} + R^{2} - 2(x')Rcos \theta '}}[/tex]
I understand that the integration over [itex]\phi '[/itex] gave you [itex]2 \pi[/itex] , but what happened to the integration over [itex]x'[/itex]?
Well [tex]d^{3}x'[/tex] turns into [tex]r^{2}sin\theta dr d\theta d\phi[/tex] and since r is constant at R (spherical shell) then an R^2 comes out of the integral and cancels the R^2 in the denominator from the charge density rho = Q / (4 pi R^2).
I also figured out the problem, after integration:
[tex]V(x) = \frac{Q}{4\pi \epsilon_{0}} \frac{1}{2xR} [\sqrt{(R + x)^{2}} - \sqrt{(R - x)^{2}}][/tex]
and I forgot to consider the different cases for [tex]\sqrt{(R - x)^{2}}[/tex] when x > R (outside spherical shell) and x<R (inside).
Since your dealing with a surface charge, and not a volume charge, you should have:
[tex]V(\vec{x})=\int \frac{\sigma (\vec{r'}) d^2 x'}{|\vec{x}-\vec{x'}|}[/tex]
where [itex]\sigma (\vec{r'})= Q/4 \pi R^2[/itex] is the surface charge density.
Yes, you're right. The form I used was ambiguous, sorry about that!
I guess I just jumped right to using [tex]R^{2}sin\theta' d\theta' d\phi[/tex] as the surface area element.
I have solved the problem though, thanks for the assistance!
No problem, but I wasn't much assistance:smile:
  • · Replies 19 ·
