Fluid Dynamics Homework: Solving for Water Speed and Range in a Container
The problem involves fluid dynamics, specifically analyzing the speed of water exiting spouts at different heights from a container and determining which stream has the greatest range. The water level is maintained at 45 cm, and the spouts are located at heights of 10 cm, 20 cm, 30 cm, and 40 cm.
  • Exploratory, Assumption checking
  • Participants discuss the application of Bernoulli's equation to find the speed of water exiting the spouts and question the height difference used in calculations.
Some participants have provided insights into the calculations, noting a specific mistake regarding the measurement units for height differences. This has led to a clarification that may help others in their understanding of the problem.
There is a focus on ensuring the correct units are used in calculations, as well as the implications of the height of the water level in relation to the spouts.
azure2s
A container has spouts 10 cm, 20 cm, 30 cm, and 40 cm. The water level is maintained at a 45 cm height by an outside supply. (a) what is the speed of the water out of each hole? (b) which water stream has the greatest range relative to the base of the container?
Bernoulli's Equation: p1 + 1/2desnityv12 + pgy1 = p2 + 1/2densityv22 + pgy2
I tried to first solve the the spout 40 cm high. Using the equation, the pressure and density gets canceled, so we have:
v12 - v22 = 2g(y2 - y1)
since v2 = 0, then
v1 = square root of 2g(y2 - y1)
v1 = square root of 2(9.8)(45 - 40)
v1 = 9.9
But my answer is wrong according to my teacher... :( Hope you can help me
since v2 = 0, then
v1 = 9.9
Your height difference is measured in cm not m.
LOL! I can't believe that was the only mistake I did! Thank you very much! =)) Now my answer is the same with my teacher's.
Good luck.
  • · Replies 21 ·
  • · Replies 17 ·
17K
