What is Maddie's final velocity after accelerating for 10 seconds?
The problem involves determining the final velocity of a character named Maddie after she accelerates negatively for a specified duration. The subject area is kinematics, specifically focusing on uniform acceleration and velocity changes.
  • Participants express uncertainty about how to approach the problem, particularly regarding the concept of negative acceleration. Some suggest using kinematic equations, while others question how to apply the equations correctly.
There is an ongoing exploration of the problem, with participants offering guidance on using equations related to acceleration and velocity. Multiple interpretations of how to apply the equations are being discussed, but no consensus has been reached.
Some participants note that there may be gaps in understanding the full set of kinematic equations, which could affect their ability to solve the problem effectively.
swede5670
Flash Maddie is running at a whopping velocity of 30 mph. She then sees Mr. T driving down the road straight towards her so she accellerates -5 mph/s for 10 seconds. what Is Maddie's velocity now. (In mph)
V = Change in distance / change in time
a = change in velocity / change in time
I'm just not sure how to approach the problem in general and I'm not sure how to approach the negative acceleration.
Whilst you could in principle use those equations, this question is best solved using kinematics equations (of uniform acceleration).
Use this equation:
Plug in the numbers you know, including any negative signs, and solve the equation. That will give you a key piece of information for solving the problem.
Hootenanny: What are these equations and how would I use them?
Red Belly: Should I multiply -5 MPH/s by 10 and then subtract it from 30 mph?
Yes, that's correct (with one minor correction, you should add the -50 to 30). In actual fact, both methods are identical:
[tex]a=\frac{\Delta v}{\Delta t} = \frac{v_f-v_i}{\Delta t}[/tex]
[tex]\Rightarrow v_f = v_i + a\Delta t[/tex]
Which is one of the kinematic equations I was referring to.
It may be that swede's class has not quite gotten to the full set of kinematic equations ... at any rate, Hootenanny is entirely right.
  • · Replies 48 ·
10K
  • · Replies 24 ·
  • · Replies 31 ·
