UN: How Will the Sun's Life Cycle Affect Our Existence?
  • Thread starter Thread starter cam875
    Heat
The discussion revolves around the generation of heat, methods to energize particles or atoms, and the mechanisms by which the Sun produces heat and light. It includes theoretical and conceptual explorations of thermodynamics, energy transfer, and nuclear fusion.
  • Some participants inquire about the easiest methods to generate heat, with suggestions including chemical and frictional processes.
  • There is a discussion on the best way to energize a particle or atom, with one participant suggesting using a high current through a resistive wire, while others propose direct photon excitation.
  • Participants debate the distinction between heat and energy, with some arguing that heat is not the same as energy and should not be used interchangeably.
  • One participant explains the process of nuclear fusion in the Sun, detailing how hydrogen atoms combine under extreme conditions to release energy in the form of heat and light.
  • Another participant emphasizes the importance of accurately distinguishing between heat and internal energy, arguing that this distinction is crucial in thermodynamics.
  • There are corrections and challenges regarding the definitions and roles of heat and work in energy transfer, with some participants asserting that heat and work are transport mechanisms rather than forms of energy.
Participants express differing views on the definitions of heat and energy, with no consensus reached on whether it is acceptable to use these terms interchangeably. The discussion on the Sun's energy production includes agreement on nuclear fusion as a source, but the details and implications remain contested.
There are unresolved nuances regarding the definitions of heat, energy, and work, as well as the complexities of thermodynamic principles that are not fully explored in the discussion.
This discussion may be of interest to those studying thermodynamics, energy transfer, and astrophysics, particularly in understanding the distinctions between heat and energy in various contexts.
cam875
can somebody tell me all the easiest ways to generate heat, it doesn't have to be a lot but some. thanks in advance.
Science news on Phys.org
When you say ''generate heat', do you mean a process that transfers thermal energy to the environment?[/
if I wanted to energize a particle or atom by applying heat to it what is the best way to do that to the particle/atom.
Although it would be practically difficult to do with an individual atom, the best method for a fluid would be to run a high current through a long coil of wire made from a material with a high resistivity. This is the same principle through which electrical heaters and incandescent light bulbs work.
Why not excite the molecules directly rather than heating up a metal object and then transfering this energy to the water. i.e. use a microwave?
It depends on what you're heating though I guess. What are you trying to heat?
Generating heat can be done through numerous processes: chemical, frictional, etc... which one is best depends on the specifics.
In these specifics, i.e. individual atoms/particles, I'd say shoot a photon at it, with the right frequency.
Edit: P.S. heat is more of a macroscopic entity. Energy = heat essentially. So you want to increase the (kinetic) energy of the atom/particle. The increased energies of individual particles in a solid/gas/whatever is what we observe as an increase in temperature.
I suggested using a heating element because the OP specifically mentioned the process of heat transfer. Of course photon excitation would be more straight forward, but then that would heat transfer.
I'm sorry but I really can't let this slide (this is a pet hate of mine), heat is not the same as energy. Heat is more analagous to mechanical work than energy.
well how does the sun produce heat and light, does it have some source of power?
Like Hootenanny has already pointed out, systems contain energy, not heat or work. Heat and work are transport mechanisms for energy across a system boundary.
CS
Energy emitted from Nuclear fusion if I'm not mistaken, and this energy gets emitted in the form of radiation.
Kinda like a L.E.D...When electrons are going across the depletion layer, they slide down a "energy hill" as they go down to lower energy levels they emit radiation in the form of a photon or light... in other diodes its emitted in the form of heat.
No, you're completely right. I was using heat in a similar context as the o.p. A more familiar usage if you will. You're right to correct it. What I should've said is that Thermal Energy = Temperature (with a constant factor of the Boltzmann constant), according to classical thermodynamics (Using Quantum Mech and Statistical Physics, there's the zero-point energy to contend with, so this isn't true in the low energy limit, I know). But increasing the kinetic energy of individual molecules/atoms increases the temperature and vice versa to increase the temperature (transfer heat to) is the same thing as increasing its energy...
But isn't it much easier to be slightly less technically accurate for the above purposes?
In the centre of the sun, under immense gravitational fields, the hydrogen molecules are moving so fast that (along with a bit of Quantum Tunnelling) they are able to overcome the coulomb interaction which separates them and combine to make Deuteron, a positron, the antiparticle pair of the electron (i.e. one proton decays into a neutron) and a bit of binding energy. A nearby electron annihilates with the positron, producing two photons a la E=mc^2 (lots of energy). Then another photon is able to fuse with the deuteron to form a light isotope of Helium. This releases more energy, because of the energy difference between the proton and the deuteron and the helium isotope. After this, the light helium can fuse either with another light helium atom to produce normal helium plus 2 hydrogen atoms, or it can combine with a normal helium atom to produce beryllium.
Most(all?) of these combinations release energy. In one full chain, we get 26.73 MeV of energy (quite a lot!). This energy appears as both heating of the sun and radiation of energy outwards from the sun (heat and light). I hope this wasn't too involved and/or confusing.
Whilst I agree that the OP incorrectly used heat as a synonym for internal energy, I cannot agree that we should not be correct in our responses simply because it is easier. The distinction between heat and internal energy is one which becomes increasing blurred, not just in the general population but also is the educational system. Many physics high school (and even undergraduate) students think of heat and internal energy as the same quantity. Whilst there isn't too much of a problem at the elementary level, once one begins to study thermodynamics the distinction between heat and internal energy is an important concept and the reason why we have two different terms.
Would you have let it slide if I'd have said "The easiest way to increase and object's work is to..." or would have said "energy = work"?
"The first law states that both work and heat are forms of energy, and that the total energy is conserved."
Kardar, Lecture 1:
http://ocw.mit.edu/OcwWeb/Physics/8-333Fall-2005/LectureNotes/index.htm
Kardar, Lecture 1:
I would have to disagree with that, instead I would say something like "The first law is a statement of the principle of conservation of energy and says that the internal energy of a system is the sum of the heat added to the system and the work done on the system.".
Work and heat are methods of energy transfer rather than forms of energy.
Kardar, Lecture 1:
This is erroneous. Systems do not contain heat or work, they contain energy. Hence, heat and work are not energy. Heat and work are energy transport mechanisms between a system and its surroundings.
Heat and work are boundary phenomena, as such they are only recognized at the boundaries of a system as they cross the boundaries.
Both are associated with a process, not a state.
Both are path functions. In other words their magnitudes depend on the path followed.
CS
wow some of this just got beyond me lol, but thanks for the informed answers.
ok I from one of the previous posts in this thread there is a lot of talk about different kinds of atoms being used in the process of radiation and everything that the sun uses. But since matter is never created or destroyed do these atoms leave the sun when there used up and travel through space to Earth or other planets and different things or do they stay and keep returning the process, and thus the sun can keep using the same matter over and over again. Because if the matter is used up or leaves the area of the sun wouldn't it eventually run out of a source of materials and basically die.
There are a lot of confused thoughts thrown together there, but the answer to the last question is yes, the sun will eventually run out of fuel and die.
so where does the matter being used up in the chemical reaction that causes the sun to do what it does go since matter can't be destroyed? or is it converted to energy like e=mc^2 and that's wat gives us light and heat.
Also when do scientists expect our sun to die? and if it does do they have a plan to keep our existence going?
http://en.wikipedia.org/wiki/Sun#Life_cycle
CS
