| Thread Closed |
rate of increase |
Share Thread | Thread Tools |
| Oct2-08, 01:04 AM | #1 |
rate of increase
The radius of a circle is increasing at a constant rate of 0.2 meter per second. What is the rate of increase in the area of the circle at the instant when the circumference of the circle is 20pi meters? 2. Relevant equations 3. The attempt at a solution I have no clue how to approach the problem |
| Oct2-08, 01:10 AM | #2 |
Recognitions:
The usual way to approach such problems is to find a relationship between the two quantities and then apply the chain rule to find the quantity you're interested in.
What is the relationship between the radius of a circle and its area? Once you have that, try differentiating both sides with respect to time. |
| Oct2-08, 01:14 AM | #3 |
a=(pi)(r^2)...
how could i differentiate a?.. dA/dt? |
| Oct2-08, 01:14 AM | #4 |
rate of increase
It's quite simple when you look at it really.
You have dr/dt (rate of increase of radius) = 0.2 where r = radius and t = time (seconds). you are looking for dA/dt where A = area of circle [tex] A = \pi r^2 [/tex] [tex] \frac{dA}{dt} = \frac{dA}{dr} \frac{dr}{dt} [/tex] <-- chain rule. [tex] \frac{dA}{dr} = \frac{d}{dr}[ \pi r^2 ]= 2 \pi r [/tex] Therefore the rule for rate of area increase = [tex] 0.4 \pi r [/tex] Now you just have to find it at the instant when circumference = [tex] 20 \pi [/tex] I'm sure you can take it from here easily. I hope I didn't give away too much. |
| Oct2-08, 01:40 AM | #5 |
Thank you :)
C = 2(pi)r r = C/2(pi) r = 20pi/2pi r = 10 dA/dt = 2(pi)r * dr/dt dA/dt = 2(pi)r * 0.2 dA/dt = 2(pi)(10) * 0.2 dA/dt = 4pi is that correct? |
| Oct2-08, 02:12 AM | #6 |
Looks fine to me. You may get marked down if you don't include units, ie. 4pi m^2 per second.
| Thread Closed |
| Thread Tools | |
Similar Threads for: rate of increase
| Will an increase of voltage also increase Amps? | Introductory Physics Homework | 1 | ||
| rate of increase of the surface area | Calculus & Beyond Homework | 6 | ||
| Einstein's:Mass increase resulting from Acceleration increase | Special & General Relativity | 30 | ||
| Rate of increase problem | Introductory Physics Homework | 3 | ||
