Equal and Opposite variable forces on a mass - does it accelerate?
The discussion centers on the dynamics of a mass attached to a spring on an air track, where the hand applies a force (F hand) while the spring exerts an equal and opposite force (F spring). Despite these equal and opposite forces, the mass accelerates due to an external force applied by the hand, which biases the system. The key takeaway is that while internal forces are equal and opposite, the external force from the hand results in net acceleration of the mass, confirming that it does not move at a constant velocity.
  • Understanding of Newton's Second Law (F = ma)
  • Basic knowledge of force and motion concepts
  • Familiarity with spring dynamics and Hooke's Law
  • Concept of closed and open systems in physics
  • Study the principles of Newton's Laws of Motion in detail
  • Learn about Hooke's Law and its applications in spring systems
  • Explore the concept of closed vs. open systems in physics
  • Investigate the effects of external forces on motion and acceleration
Physics students, educators, and anyone interested in understanding the principles of force, motion, and dynamics in mechanical systems.
Erica799
1. A mass is attached to a spring that is mounted on the end of an air track. The mass is pushed by your hand along the track, providing a force, F hand. The spring provides a force on the mass, F spring, equal to F hand but opposite in direction. Assume (frictionless?) air track is being used. The forces vary linearly (classic F vs x, work is area under the curve, net work equals zero on the spring/mass system.) How do I explain why the mass moves, if the forces on the mass are always equal and opposite? Is the mass accelerating, or moving at a constant velocity? I am confused!
f(t) = m (dv/dt) ?
If there is a force, there is an acceleration. Think of [tex]F = ma[/tex]
As for why it moves. You are correct, your hand pushing on the mass is the same force of the mass pushing back on your hand. However, this is looking at it as a closed system. More force is coming outside of your defined system that is 'biasing' the direction of the force (ie. from you).
I just realized that biasing is a really bad word to use in this context. More force is added from outside the system to overcome the force that is pushing back on your hand. The equal and opposite force for this force is also located outside the system.
Hope that makes sense.
  • · Replies 31 ·
  • · Replies 27 ·
  • · Replies 98 ·
  • · Replies 30 ·
