Thread Closed
Shielding Effect and Chemical Shift
Share Thread Thread Tools
Oct2-08, 11:00 PM   #1
Given a molecule of chloroethene (vinyl chloride) or ClCH=CH2. Rank the hydrogen atoms in the molecule in terms of which will have the greatest chemical shift.
2. Relevant equations
None
3. The attempt at a solution
Since the Cl and the double bond are both electron-rich, this affects the shielding of each proton. So to rank them, I think it could go one of two ways:
1) The proton on the Cl-CH= is the most blinded (smallest chemical shift) since it is between the two electron-rich groups, followed by the proton in the cis position to the Cl since it is slightly closer to the electronic density than the H in the trans position to the Cl.
OR
2) The reverse order so: the H on the Cl-CH= is the least blinded (largest chemical shift) because the Cl is electronegative and is withdrawing the electron density from the H. Then the H in the cis position to the Cl would be 2nd rank in terms of blinding and then followed by the H in the trans position to the Cl (being the least blinded) because all of its electron density is being pulled toward the double bond and the Cl.
I think I'm a bit mixed up on how electronegativity works, so any help would be greatly appreciated. Thanks in advance!!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Oct8-08, 11:07 AM   #2
Other Sciences 2012
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Quote by edimeo25 View Post
OR
No. Halogens are electron rich relative to a similar carbon group but they get that way in part because they withdraw electron density from the carbon they are attached to. Therefore, the remaining carbon is electron-deficient so the geminal C-H bond is polarized with more electron density being pulled toward the carbon. This effect is called de-shielding.
Thread Closed
Tags
electronegativity, shielding, shift, spectroscopy
Thread Tools
Similar Threads for: Shielding Effect and Chemical Shift
Thread Forum Replies
Effect of accel/velocity on chemical reactions Chemistry 10
Red Shift and Doppler Effect General Physics 2
Red shift, blue shift, or stupidity? Special & General Relativity 6
chemical effect of electric current Introductory Physics Homework 4
Doppler shift and red/blue shift General Astronomy 4
