2nd law of Thermodynamics and black body brightness function
The discussion revolves around the implications of the second law of thermodynamics in relation to the brightness function of black bodies and their thermal equilibrium. Participants explore the conditions under which energy exchange occurs between black body cavities and the constraints imposed by thermodynamic laws.
  • One participant expresses confusion about why spontaneous energy flow between two systems in thermal equilibrium would violate the second law of thermodynamics.
  • Another participant argues that if the brightness function differs, it would lead to unequal energy exchange, resulting in one body heating up and the other cooling down, thus violating the second law.
  • A third participant clarifies that while spontaneous fluctuations in energy flow are permissible, the net flow must average to zero at equilibrium.
  • One participant raises a concern regarding the implications for greybodies in thermal equilibrium with blackbodies, referencing literature that suggests equilibrium cannot be established between cavities of different sizes at the same temperature.
  • A later reply questions the validity of the argument if the filtering of radiation is not done with infinite precision, referencing a specific paper on finite size corrections to blackbody radiation laws.
Participants exhibit uncertainty and disagreement regarding the implications of the second law of thermodynamics, the conditions for thermal equilibrium, and the role of filtering in energy exchange. No consensus is reached on these points.
Participants note limitations related to the definitions of blackbodies and greybodies, the assumptions about energy flow, and the implications of cavity size on thermal equilibrium. These factors remain unresolved in the discussion.
pastro
Hi,
I feel extremely stupid for having to have this explained to me, but I am really confused by it. I recently encounter a proof of the fact that the brightness (energy/(time x area x solid angle x frequency)) of a black body can only depend on its temperature, not the properties of the enclosure itself. Here is the argument:
"Two black body cavities at the same temperature are brought near each other. They each have a tiny hole so that they can exchange radiation with each other. A filter which only allows radiation of frequency [tex]\nu[/tex] to pass between them is placed between the holes. If the brightness function of the two is not the same, energy will spontaneously flow from one cavity to another, which violates the second law of thermodynamics. Thus, the brightness functions of the two black bodies must be the same at a given temperature."
The part I don't understand is why the spontaneous flow of energy between two systems in thermal equilibrium violates the second law of thermodynamics. If I casually think to myself, "the second law gives the time arrow of energy, and energy only flows from hot to cold, then heat flow between bodies at equal temperatures must be a violation," then I get what is meant. But, if I write,
[tex]\frac{\delta Q_{total}}{T}\geq 0[/tex] and [tex]\delta Q_{body1}[/tex]=-[tex]\delta Q_{body2}[/tex], then the second law reads [tex]\frac{\delta Q_{body1}+\delta Q_{body2}}{T}\geq 0[/tex] so [tex]\delta Q_{body1} \times 0 \geq 0[/tex]
I don't see the contradiction, or how this puts a constraint on [tex]\delta Q_{body1}[/tex]
pastro
Science news on Phys.org
If the brightness function is not the same then one body will have more energy at frequency [itex]\nu[/itex] than the other. Therefore, one will lose more energy to the other body than it gains from that body. This means that one body will get hotter and one body will get colder. This violates the second law (Clausius statement).
AM
As AM points out, the argument works because the prohibition is on *net* flow. Spontaneous non-zero fluctuations in energy flow are allowable, but in thermodynamics must average to zero at equilibrium.
The confusing thing to me this seems to imply that a greybody cannot be in thermal equilibrium with a blackbody.
I looked up an article by Duley (Blackbody radiation in small cavities, Am J Phys 1972) which says that a perfect blackbody must be a large cavity, and that equilibrium cannot be established between a large and a small cavity at the same "temperature". The cavities' energy densities are different for large wavelengths. If the cavities are connected by a small hole, only small wavelengths can pass through the hole, and in this particular case they can be in equilibrium. If this is correct, then in addition to the second law, isn't the zeroth law about the existence of "temperature" also needed for the argument?
I found some notes by Brown (http://www.strw.leidenuniv.nl/~brown/college_sterren/BlackbodyThermodynamics.pdf) which make more sense to me by filling in gaps in the argument quoted in the OP.
Garcia-Garcia, Finite size corrections to the blackbody radiation laws, http://arxiv.org/abs/0709.1287
Looking at Fig. 1 in the above paper, it seems the argument is not going to work unless we cannot filter with infinite precision?
  • · Replies 16 ·
  • · Replies 152 ·
12K
  • · Replies 20 ·
9K
