| Thread Closed |
Simple harmonic oscillator |
Share Thread | Thread Tools |
| Oct3-08, 03:18 PM | #1 |
Hi all,
I have to determine the potential energy of a hanging spring with a mass m in the end and spring constant k. I try to write down the force in the system F = m*g + k*x and integrate the force in order to get the potential energy E_p = m*g*x+0.5*k*x*x Does this look correct and is it possible to derive the mean displacement from the potential energy if one could neglect the kinetic energy. Thanks in advance Best regards M |
| Oct3-08, 05:20 PM | #2 |
Mentor
You're expression for E_p is correct. I'm assuming you're taking upward as the positive direction. Your force expression has +/- sign issues, by the way.
The mean displacement is where E_p has a minimum value. So yes, it's possible to derive mean displacement from your E_p expression. |
| Oct4-08, 03:09 PM | #3 |
Hi,
thanks for the answer. So the mean is when m*g = k*x solving for x x = m*g/k which results in the mean elongation of the spring is <dis> = 0.5*m*g/k Is this correct? Thanks in advance all the best |
| Oct4-08, 04:34 PM | #4 |
Mentor
| Oct5-08, 02:13 AM | #5 |
hi,
I am a little bit puzzled where my mistake is... I differentiate my expression for the potential energy in order to find a stationary point d(E_p) = m*g - k*x setting this equal to zero and solving for x x = m*g/k than I set this into the equation for the potential energy as I presume this is the minimum E_p = m*g*(m*g/k)-0.5*k*(m*g/k)^2 = 0.5 * (m*g)^2/k this I would presume is the expression for the mean elongation? Where does I misunderstand thanks in advance All the best |
| Oct5-08, 06:38 AM | #6 |
Mentor
When you get
x = mg/k you can stop, because that is the mean elongation. |
| Oct5-08, 03:10 PM | #7 |
thanks,
if I want to estimate the variance of the elongation var = 1/N sum (xi-x_mean)2 I know the mean is x_mean = m*g/k which I insert into the expression and integrate from minus to plus infinity var = [tex]\int(m*g-k*x-m*g/k)^2 dx[/tex] Could anyone give a hint if this is on the right track? Thanks in advance all the best M |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Simple harmonic oscillator
| Simple Harmonic Oscillator Help | Introductory Physics Homework | 2 | ||
| Simple Harmonic Oscillator | Introductory Physics Homework | 0 | ||
| 1-D simple harmonic oscillator | Advanced Physics Homework | 3 | ||
| QM simple harmonic oscillator | Advanced Physics Homework | 0 | ||
| Simple Harmonic Oscillator | Introductory Physics Homework | 8 | ||
