Oxidation or Reduction: NO3- to NO?
The half-reaction from nitrate (NO3-) to nitric oxide (NO) is classified as a reduction process. In this reaction, nitrogen transitions from an oxidation state of +5 in NO3- to +2 in NO, indicating a gain of electrons. The overall charge shifts from -1 to 0, confirming that electrons are added to the nitrogen atom, which is characteristic of reduction. The oxidation states of oxygen were incorrectly stated as -6; each oxygen atom has an oxidation state of -2, totaling -6 for three oxygen atoms.
  • Understanding of oxidation states and how to calculate them
  • Familiarity with redox reactions and their definitions
  • Knowledge of half-reactions in electrochemistry
  • Basic chemistry concepts regarding electron transfer
  • Study the principles of oxidation and reduction in redox reactions
  • Learn how to balance redox half-reactions using the half-reaction method
  • Explore the concept of oxidation states in various chemical compounds
  • Investigate common redox reactions in organic and inorganic chemistry
Chemistry students, educators, and anyone studying redox reactions and oxidation states in chemical processes.
Kabloom
Is this oxidation or reduction: (NO3)- ---> NO (this is a half reaction I took from the full equation)
Not necessary
At first, I got the oxidation states of each of the atoms
For (NO3)- N has an oxidation state of 5+ and O has an oxidation state of 6-.
for NO N has an oxidation state of 2+ and O has an oxidation state of 2-.
and then I look at the charge of the whole compound.
It goes from - to 0.
therefore, i concluded that this is a oxidation equation.
but it is actually a reduction equation
Did I overlook something?
That is a reduction. Look at it this way:
NO3 supscr -1 gives (-2)*3 charge from the oxygens. The charge on the Nitrogen is what? x + (-2)*3 = -1 means x=+5.
Now, what happened in the half reaction? What is the charge that the Nitrogen now carries? How many electrons were gained OR how many electrons were lost? If the Nitrogen had to gain electrons then the half reaction was a reduction. If the Nitrogen had to loose electrons then the half reaction was an oxidation.
So, what happened to nitrogen, did it ON went up or down?
Note: while ON for N are OK, you can't write
There were three O atoms, each with ON -2. It is not the same, as your statement suggests each atom was -6.
