Thread Closed
Internal energy does or does not depend on volume of molecules?
Share Thread Thread Tools
Oct4-08, 02:27 AM   #1
I am kind of confused by the conflict of the following two concepts.
If I understood correctly, internal energy of a system is independent of the volume occupied by the gas molecules. This is because the gas molecules are assumed to be ideal and therefore have no intermolecular interactions. (Hence volume doesn't matter)
This is proven to be true in adibatic change, where both volume and temperature changes.
If I understood correctly, this adibatic change can be divided into volume change at constant temperature, and temperature change at constant volume.
However, for the change in the internal energy, only the second step matters and hence delta U = Cv (Tf-Ti)
I fail to see how this applies in expansion work. In expansion work, delta U = w + q.
w = Pex x delta V for irreversible expansion
and
w = -nRTln(Vf/Vi) for isothermal reversible expansion.
Well if work is done, then the internal energy must change. So wouldn't this mean that the internal energy is dependent on the volume of the molecules?
(Unless of course the heat supplied by the surroundings is equal to the work done by the system to keep the process isotherma; and these two cancel each other out to give delta U = 0?)
Thanks!
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Iron-platinum alloys could be new-generation hard drives
>> Lab sets a new record for creating heralded photons
>> Breakthrough calls time on bootleg booze
Oct4-08, 03:38 AM   #2
Recognitions:
Quote by p3t3r1 View Post
Yes:
http://hyperphysics.phy-astr.gsu.edu...rmo/isoth.html
Thread Closed
Thread Tools
Similar Threads for: Internal energy does or does not depend on volume of molecules?
Thread Forum Replies
What is Internal Energy + Pressure * Volume Classical Physics 8
[SOLVED] Rotational Kinetic Energy and distribution of diatomic molecules Advanced Physics Homework 3
volume of vessel occupied by molecules Introductory Physics Homework 2
how does frequency depend on the potential energy? Classical Physics 2
does the type of energy depend on the particle carying it??? General Physics 5
