Circular Motion, Velocity at top/bottom question
The discussion revolves around calculating the forces acting on a rider in a 16-meter diameter rotating ring amusement park ride. The ring completes one rotation every 4.5 seconds, resulting in a linear velocity of 11.17 m/s. The acceleration at the top of the ride is calculated to be 15.6 m/s², leading to a normal force of 857.8 N at the top. The equations provided in the textbook clarify the differences in normal force calculations at the top and bottom of the circular motion.
  • Understanding of circular motion dynamics
  • Familiarity with Newton's laws of motion
  • Knowledge of centripetal acceleration
  • Ability to apply kinematic equations
  • Learn how to calculate centripetal force in circular motion
  • Study the differences in forces at the top and bottom of vertical circular motion
  • Explore the concept of uniform circular motion in physics
  • Investigate the role of gravitational force in circular motion dynamics
Physics students, educators, and anyone interested in understanding the dynamics of circular motion in amusement park rides.
swooshfactory
In an amusement park ride, passengers stand inside a 16-m-diameter roating ring. After the ring has acquired sufficient speed, it tilts into a vertical plane.
Suppose the ring rotates once every 4.5 seconds. If a riders mass is 55 kg, with how much force does the ring push on her at the top of the ride? At the bottom?
First I solved for velocity:
8 m radius * 2pi = 16pi m circumference
16pi m / 4.5 s = 11.17 m/s
Then acceleration:
a=(v^2)/r = (124.77)/8= 15.6 m/s^2
Sum of forces in radial direction at top = n + mg = ma = 55 kg * 15.6 m/s^2 = 857.8 N
n + mg = 857.8 N
If I follow this logic, I would get the same answer for the sum of forces at the bottom.
My book gives the equation n=mg + [m(v_top)^2]/r and n= [m(v_bottom)^2] - mg .
I understand this, because at the top, the normal and gravitational force point in the same direction, and at the bottom they point in different directions. The problem is, I don't know how to computer the velocity at the top or at the bottom. My book also gives the equation v_c = sqrt(rg) which is the slowest speed at which the object can complete rotation, but I don't think this ride is traveling near that speed.
Can anyone tell me how to find the velocity at the top or bottom of circular motion? I'm pretty sure this is uniform, but I'm not sure.
Hi swooshfactory! :smile:
Yes it is uniform … the question makes that clear.
It's a powered ride. :smile:
  • · Replies 18 ·
