How Is Work Calculated in an Elevator Physics Problem?
The discussion revolves around a physics problem involving work calculation in an elevator scenario, specifically focusing on the forces acting on a block of cheese inside the elevator cab. The problem includes two parts: calculating the work done by the cable on the cab and determining the normal force acting on the cheese during the elevator's movement.
  • Mixed
  • Participants explore the relationship between tension, normal force, and gravitational force in the context of the elevator system. There are attempts to clarify the net forces acting on the system and how they relate to the work done by the cable.
Some participants have provided insights into the calculations and the roles of different forces, while others express confusion about the net force calculations. There is ongoing exploration of the correct approach to solve Part B of the problem, with suggestions to reconsider the net force and the role of the normal force.
Participants are working under the constraints of a homework assignment, which may limit the information they can share or the methods they can use. There is a specific focus on ensuring the calculations align with the principles of physics regarding forces in a system.
ctpengage
A 0.250 kg block of cheese lies on the floor of a 900 kg elevator cab that is being pulled upward by a cable through distance d1 = 2.40 m and then through distance d2 = 10.5 m. (a) Through d1, if the normal force on the block from the floor has constant magnitude FN = 3.00 N, how much work is done on the cab by the force from the cable? (b) Through d2, if the work done on the cab by the (constant) force from the cable is 92.61 kJ, what is the magnitude of FN?
2. The attempt at a solution
Solution Part A
The net upward force is given by
FTension + FN - (m+M)g = (m+M)a
where m = 0.250 kg is the mass of the cheese, M = 900 kg is the mass of the elevator cab,
F is the force from the cable, and 3.00 N N F = is the normal force on the cheese. On the
cheese alone, we have
FN - mg = ma
Therefore a = [3.00-(0.250)(9.80)] / 0.250 = 2.20 m/s2
Thus the force from the cable is F FTension = (m+M)(a+g) - FN = 1.08 x 104 and the work done by the cable on the cab is
W = FTensiond1 = (1.08 x 104)(2.40) = 2.59 x 104[/SUP
However I am stuck on Part B. The answer for Part B is 2.45 N. Can anyone please help me on Part B? Thanks guys.
Anyone please help?
The net force on the entire system (cab + cheese) would not include the normal force. The normal force is internal to the system and acts on both cab and cheese, but in opposite directions.
On the
FN - mg = ma
Good.
Redo this calculation using the correct net force.
Start by finding the cable tension. Then just work backwards, using the same approach as above.
Good.
Why was my net force wrong?
See my last post:
  • · Replies 31 ·
23K
