What are the image charges inside the spheres?
The discussion revolves around calculating the electric field between a charged sphere and a grounded plate, exploring the method of images and the implications of image charges in this configuration. Participants delve into theoretical aspects, mathematical formulations, and the complexities involved in the problem.
  • Some participants suggest using an image sphere held at a negative voltage on the opposite side of the plate to simplify calculations.
  • There is a discussion about how the radius of the sphere affects the electric field strength, with some noting that a smaller radius leads to a higher electric field.
  • Participants question the assumptions made about the plate being an infinite plane and discuss the implications of field lines and equipotential surfaces.
  • One participant emphasizes the need to set up the Green's function for the geometry, indicating that this is a non-trivial problem requiring advanced understanding.
  • There are mentions of using an infinite series of image charges and the complexities involved in integrating these charges, particularly in relation to spherical coordinates.
  • Concerns are raised about the conservation of charge when using image charges, with some clarifying that charge can flow if the spheres are held at constant potentials.
  • Participants discuss whether the method of images is unique to spheres or applicable to other geometries, such as parallel cylinders.
Participants express varying levels of familiarity with the concepts involved, leading to a mix of agreement on the use of image charges and disagreement on the specifics of charge conservation and the complexity of the problem. The discussion remains unresolved regarding the exact formulation of the electric field and the implications of the image charge method.
Some participants indicate limitations in their understanding due to a lack of recent study or resources, which may affect the depth of the discussion. The problem's complexity is acknowledged, particularly in relation to setting up the necessary mathematical framework.
eintagsfliege
Hi together
I want to calculate an electrical field between a sphere and a plate, where the sphere has a certain voltage and the plate is on ground.
Has someone a suggestion to begin?
Put an image sphere held at -V on the other side of the plate.
The more little the radius of the sphere is, the higher the electric field grows.
But how should the formula look like for the electric field?
plate=infinite plane? (i.e. much larger than the sphere and much larger than the distance between the sphere and the plane)
are you familiar with lines of flux?
Ben's suggestion of an image sphere is correct, but there is more to the problem.
You should know how to do a point charge and a conducing sphere at V.
You have to keep adding image charges in a series to get the pot for two spheres.
Did you not read what Ben Niehoff suggested?
The problem with your question here is that you neglected to let the rest of us know what YOU know, i.e. are you able to solve the typical advanced undergraduate E&M problem? Can you solve Poisson's equation? Are you familiar with the method of images?
Someone familiar with those would have automatically understood what is meant by putting an image sphere on the other side of the plate.
Zz.
I am sorry.
Some years ago, I had lectures about Electrodynamics. Unfortunately, I don't have my books here. But so far I remember these Image Method.
I just can't remember how to calculate the electrical field between the inifinite plate and the charged sphere with a radius a.
Maybe someone has a little time to explain.
I misunderstood the question.
post 2 is pretty much all there is to it.
Draw rings of constant field strength about the sphere at uniform intervals. When the rings reach the plate, connect the ends (at ground) using an arc of the same radius - but from the center of a mirror image of the sphere (i.e. mirrored across across the ground plane).
Field strength falls off with with 1/r, so each succesive ring represents 1/n of the field at the first ring (i.e. 1/1, 1/2, 1/3, ...). Vector add the direct and reflected fields where the rings cross over.
Regards,
Bill
and there is no field at all on the other side of the plate?
No field, just the one of the sphere and the plate
I mean due to the sphere
eintagsfliege said:
I am sorry.
This is NOT a simple problem. You have to set up the Green's function for the geometry using the image sphere at an opposite potential as your real sphere. This is the only geometry that will give you the same boundary condition on your infinite plate. Setting and solving this isn't trivial, especially if you haven't done this in a while or haven't done Jackson.
Zz.
ah yes the plate is an equipotential (its at ground) so the field lines must enter it at right angles.
True!
Could you give me a hint to set up the green function for a sphere?
The problem of two spheres is quite non-trivial. Do you know the Green function for a point charge near a conducting sphere, in spherical polar coordinates? You will need to take that Green function, and integrate it over the second sphere.
Alternatively, you can consider an infinite series of image charges, derived by finding the images of each sphere in the other, recursively, ad infinitum.
Yet a third way is to take the Green function for a point charge above an infinite plane, and integrate that over your original sphere.
Any way you cut it, the problem is not simple.
I've never heard of this before. Is this common with other geometries or is it particular to spheres? are the image charges inside the spheres? if so then how is the net charge of the sphere conserved?
It works with parallel cylinders, too, although in that case it is probably easier to use conformal mapping.
The image charges are placed inside the spheres, yes. Charge is conserved by placing equal and opposite image charges at the centers of the spheres, as well. I.e., if the sphere has charge Q and a particular image charge is q, then you place q at the image location, and put -q at the center of the sphere.
However, if the spheres are held at constant potentials, then charge isn't conserved anyway (because it can flow through whatever apparatus holds the spheres at constant potential).
  • · Replies 16 ·
